CNC Desktop Machines.
- smprobban
09 Apr 2013 15:03 - 09 Apr 2013 15:04 #32457
by smprobban
CNC Desktop Machines. was created by smprobban
Hi all again
www.alecop.com/equipment/index.php/en/di...manufacturing/lathes
Will this ones be possible to run linuxcnc? I know they arent any expert stuff but i just want to learn linuxcnc
so i mailed em for prices but as iam a n00b i wont buy anything i dont know if it will be usable with linuxcnc.
Thanx in advance
Robin
Thanx in advance
Robin
Last edit: 09 Apr 2013 15:04 by smprobban.
- jmelson
- Thank you received: 160
11 Apr 2013 11:10 #32552
by jmelson
with a simulator for big machine control panels. I don't know if they will sell just the
lathe without their software (which is their real product). So, I'm guessing the whole kit will
be quite expensive.
And, then you'd have to tear it apart to get at the connections to run it from LinuxCNC.
I suspect there would be much cheaper routes to get a small lathe running.
Jon
Replied by jmelson on topic CNC Desktop Machines.
These are meant for teaching CNC programming on commercial machine controls, and comeHi all again
be quite expensive.
Jon
- smprobban
11 Apr 2013 12:58 #32554
by smprobban
Replied by smprobban on topic CNC Desktop Machines.
Thanx for the answer then i know
- Thank you received: 4994
11 Apr 2013 19:25 #32563
Replied by andypugh on topic CNC Desktop Machines.
This ought to work, but isn't exactly cheap
www.amadeal.co.uk/acatalog/copy_of_Lathe.html
I have seen much neater conversions too.
Time to create page: 0.059 seconds
