IBC912
- dish_moose
01 May 2013 23:47 #33496
by dish_moose
IBC912 was created by dish_moose
I am trying to get LinuxCNC working with my old IBC912 that has 2 solenoids to plunge the z axis. I am using the z direction to control the first solenoid. I need to be able to turn on the 2nd solenoid after a slight delay and before the spindle move in the XY. I'm very green using linuxcnc so be gentle.
-Bruce
-Bruce
- BigJohnT
- Thank you received: 1176
01 May 2013 23:53 #33497
by BigJohnT
Replied by BigJohnT on topic IBC912
Do you have any feedback on the Z axis to indicate that it has moved? Ie. a prox for up and a prox for down?
I'd use M1xx commands to fire the solenoids similar to what I do with my collet closer on my Hardinge CHNC lathe.
Examples are in the manual.
- dish_moose
02 May 2013 00:15 #33499
by dish_moose
Replied by dish_moose on topic IBC912
As it stands right now - I just use the time to do it's imaginary steps in the -z direction with no feedback. When the z dir changes, I need another i/o pin to activate the 2nd solenoid after a short delay(1/2 second) and I need the 2nd solenoid to turn off at the same time it goes positive.
-Bruce
BTW thanks for the look
-Bruce
- BigJohnT
02 May 2013 01:47 #33500
by BigJohnT
Also look at classicladder in the manual for sequencing operations with timers.
- dish_moose
16 May 2013 23:59 #34208
by dish_moose
I'm trying to get my digital output dout-01 to be set when my zdir bit gets set. I have a single rung in CL with %I0 associated with zdir but I can't seem to get my %Q0 to turn on. I also don't have any extra lines in my postgui.hal file. I think I'm missing something very basic.
-Bruce
-Bruce
- BigJohnT
18 May 2013 04:03 #34285
by BigJohnT
Can you attach the .clp file?
Did you make the connection in hal?
Watch the ladder with the ladder editor and make sure your output in classicladder toggles as you expect then open show hal configuration from the Axis menu and add your pins to a watch window to observe them.
JT
JT
- dish_moose
18 May 2013 05:32 - 18 May 2013 05:33 #34295
by dish_moose
I read it many times yet still missed the fact that in the postguihal I need to relate symbols in CL to the HAL - will try it Monday when I get back to work.
-Bruce
EDIT:
i'm used to software that does it all for you.
-Bruce
EDIT:
Last edit: 18 May 2013 05:33 by dish_moose. Reason: Additional info
Time to create page: 0.055 seconds
