Arduino to fill a gap
- Goosey
14 Jun 2013 09:03 #35608
by Goosey
Arduino to fill a gap was created by Goosey
Built a cnc router. Mechanical part is done, motors mounted. Opto-isolator output from paraport is finished. Also have h-bridges rigged for two inputs per stepper, 6 total.
The only missing part is translator (I think it's called). If I had some jk flip flops and some xor's, I could do what's left in hardware but I've built this out of what I have on hand so far so have decided to use the Arduino Uno to finish out.
If I could find a uno library that uses parallel port step/dir signals for input, as well as convert them into the correct 2 bit signals for the h-bridge, I'd be set. Baring that, I guess I've actually got to learn the language Uno uses and write it myself.
On the other hand, if someone has already written this type sketch/library, I'd love to get right to learning how to run LinuxCNC and get past the steep part of THAT curve.
Any assistance much appreciated.
- Thank you received: 5272
14 Jun 2013 11:33 #35609
Replied by PCW on topic Arduino to fill a gap
You may find that the LinuxCNC step generator can already output the
correct step pattern that you require:
www.linuxcnc.org/docs/html/hal/rtcomps.html
The following user(s) said Thank You: Goosey
- Goosey
14 Jun 2013 15:03 #35612
by Goosey
Replied by Goosey on topic Arduino to fill a gap
Guess it'd pay me to start digging deeper into LinuxCNC already, huh? I'm thinking the type stepgen I need is quadrature, at least someone told me that.
From my studies, the step/dir is generated sequentally on 2 pins as such;
00 01 10 11 while the sequence for the steppers is 00 01 11 10. Can it output that sequence?
- ArcEye
- Thank you received: 758
14 Jun 2013 15:17 #35613
by ArcEye
Replied by ArcEye on topic Arduino to fill a gap
Hi
As I understand it, quadrature is 2 waves, 90 degree out of phase
Look at step type 2 in the link PCW posted
- cncbasher
- Thank you received: 288
14 Jun 2013 15:19 #35614
by cncbasher
Replied by cncbasher on topic Arduino to fill a gap
- Goosey
14 Jun 2013 20:52 #35623
by Goosey
I think HAL will be the one to fill the gap. Dave would be proud.
It's like virtual circuitry. And unless I miss my guess, by not converting the output signals into step/dir, I might actually get fewer instructions between the cut file and my motors, thus less chance for latency. Depends on how it's written i guess.
Thank you all for your help. Guess I can use my Arduino for other stuff now, since it obviously isn't needed here.
- Thank you received: 4995
15 Jun 2013 06:05 #35655
It is also pretty easy to write your own HAL components too, using a simplified form of C.
www.linuxcnc.org/docs/html/hal/comp.html
Replied by andypugh on topic Arduino to fill a gap
