A 6 DOF robotic arm as a milling machine?
06 Jul 2013 17:45 #36358 by Rips Raps
I have always dreamed of cheap 5 axle CNC machining mill. It should be possible to CNC-machine a car with that or similar complex object like a human head.
But is there any sense to buy a low cost 6 DOF robotic arm from ebay and use it as a tool like this:
www.ebay.com/itm/New-6-DOF-Manipulator-A...&hash=item257c457338
Is it difficult to make exactly this robotic arm to work with Linux CNC or some CAM commercial software? Is there a ready software solution?
Maybe the table where the machinable object is fixed could have such an function that it could rotate with a servo. But I think that in theory a robotic arm with a
table like this should be able to machine whatever form.
Please tell me your opinions of a plan like this. Many thanks in advance.
06 Jul 2013 20:09 #36360 by emcPT
Replied by emcPT on topic A 6 DOF robotic arm as a milling machine?
You are asking for opinions, so mine is: too complex with high probability of no success. In fact the base machine is very weak and probably will fall down when you place a milling head on it...
06 Jul 2013 23:19 - 06 Jul 2013 23:20 #36364 by cncbasher
Replied by cncbasher on topic A 6 DOF robotic arm as a milling machine?
it would be difficult to make the type of robotic arm shown to do anything useful , for what you describe you would be better off looking for an industrial puma style robot
please grasp the thoughts that you need MASS and strength to be able to withstand the cutting forces applied without the arm moving off position , this in essence requires gearing and solid building .
the arm shown uses rc servos which lacks strength or suitable gearing etc ..
but yes what your looking for can be done , but their not cheap due to the construction needed
but to answer your question Linuxcnc is able to handle it ( up to 9 axis ) , however 5 axis or more cam software is not cheap .
Last edit: 06 Jul 2013 23:20 by cncbasher.
07 Jul 2013 03:47 #36368 by BigJohnT
Replied by BigJohnT on topic A 6 DOF robotic arm as a milling machine?
I can imagine the end effector falling off after a short while being connected to a RC servo output shaft with that much moment arm.
That is surely just a toy...
JT
07 Jul 2013 09:30 #36380 by andypugh
Replied by andypugh on topic A 6 DOF robotic arm as a milling machine?
But is there any sense to buy a low cost 6 DOF robotic arm from ebay and use it as a tool like this:.
No, that is a toy. You would be wasting your time.
The idea is sound:
But you need to consider the cutting force, then from that you can calculate the joint torques, and you will find that you probably need something really quite sturdy.
11 May 2016 09:59 #74494 by 3D-innotech
Replied by 3D-innotech on topic A 6 DOF robotic arm as a milling machine?
Hello
That is exactly what i need
low accuracy +-0.5mm
materiel is polystyrene
so even the motor is light and powerless
i want to make 3d models from a 3d file, say OBJ
and make a small 3D real model
today im doing it with a 3 axes machine and it is so low tech....
please advise
11 May 2016 13:41 #74510 by andypugh
Start by considering how you will create the 5-axis G-code. That aspect can be expensive.
12 May 2016 22:01 #74572 by LearningLinuxCNC
Replied by LearningLinuxCNC on topic A 6 DOF robotic arm as a milling machine?
please advise
If you can do it with a 3 axis machine then there is no need to complicate the situation to make it more high tech. The old KISS comes into play here. The only reason to go from 3 axis to more is if you physically can't make the part with a 3 axis machine or the investment in time and money to go to 4 or 5 or 6 ... or 9 will be paid off by improvements in cycle time.
Now if it is just for fun then go for it and give it a try. If it does not work then so what you can still do it the old way with your 3 axis machine.
My 2 cents.
Time to create page: 0.335 seconds
