My new CNC, deep aluminium pocketing test
- laurent_parti
- Thank you received: 11
10 Jul 2013 15:14 #36489
by laurent_parti
My new CNC, deep aluminium pocketing test was created by laurent_parti
Hi all,
I have a new project and want to test my new CNC machine, so I make some trials and results are amazing:
DEEP ALU POCKETING
Laurent
DEEP ALU POCKETING
Laurent
- Thank you received: 4995
10 Jul 2013 21:59 #36508
Replied by andypugh on topic My new CNC, deep aluminium pocketing test
I think that might technically be shallow pocketing lots of times in the same place
Glad to see it worked, though.
You probably need some stronger hold-down clamps.
- laurent_parti
27 Jul 2013 00:42 #37075
by laurent_parti
Replied by laurent_parti on topic My new CNC, deep aluminium pocketing test
Hello Andy,
Sure, your comments make sense. For the clamps, I created them the first itme I wanted to test the machine and they are still in use ! Shame on me . . .
In the other hand, I tried some a new challenge:
SMALL GROOVE ON FACES
Laurent
Laurent
27 Jul 2013 01:20 #37076
I still don't think that should be possible on a wooden machineSMALL GROOVE ON FACES
- laurent_parti
31 Jul 2013 17:40 #37288
by laurent_parti
- Thank you received: 1467
31 Jul 2013 20:48 #37293
It isn't that surprising, he's cutting pretty slowly with fairly high rpms, in aluminum so loading is pretty small and wood does a decent job of dampening small vibrations. What is surprising is that he isn't smearing the aluminum more than he is. (bet tool life isn't all that great.)
Looks like he is making the best of what he has to work with.
Replied by Todd Zuercher on topic My new CNC, deep aluminium pocketing test
- laurent_parti
31 Jul 2013 21:10 #37295
by laurent_parti
Hello Tood,
You point it right. Slow speed generate slow forces and wood absorb a lot of vibrations so helps with small mill.
Regarding chips burning or welding, the air nose is not a standard one and comes for Kool mist ( Kool Mist )
It has the ability to drasticaly reduce the temperature of air blow with some small drops of coolant. So with a wooden machine, there is not a coolant flow that the machine can not appreciate but a real coolant effect. That's why it works pretty well for cooling.
There is also an other supplier than uses a vortex device to decrease air temperature about 15/20° (price is higher and I don't remember its name) so you can suppress any coolant but some testings have to be made before.
As I use Kool Mist an a daily basis, I trust it !
Hope those infos will help
Laurent
Laurent
Time to create page: 0.080 seconds
