[NEWBIE] Advises creating a cnc wood roter
- petekaner
31 Jul 2013 22:07 #37299
by petekaner
[NEWBIE] Advises creating a cnc wood roter was created by petekaner
Hello everybody,
Now, first of all, I don't expect a detailed how to, just some advices
So here's the deal. My brother and I are plannig to build a wood router to create slot car circuits, things like these:
So what we have in mind is:
njdiding.en.made-in-china.com/productima...-1215-1218-1325.html
So my quick questions are:
Any other recommendation you have will be much more appreciate. We are absolutely newbies on this
Thanks a lot
Ah, and keep in mind this is very important, we're talking about slot cars here
- A 3 axis router wich can "draw" the slot
- The size of the circuit will be max 120mm x 80mm
- The routing will be done with a router like this: workingwoodplans.files.wordpress.com/201...-working-routers.jpg
- what would recommend? step or lineal motors?
- any recomendations on the controller? I'm thinking on tb6560 3 axis
- we have an old computer which seems just perfet for the job, we will build the bench ourselves as well as everything else, but we will obviously will have to but motors, controllers... how much more or less do you think it will cost?
- cncbasher
- Thank you received: 288
31 Jul 2013 23:30 #37300
by cncbasher
Replied by cncbasher on topic [NEWBIE] Advises creating a cnc wood roter
well you certianly will be jumping into probably some of the unknown , but first of all some basics .
depending on your available cash flow , this will not be a cheap fix , expect something in the order of $3,000 - $4,000
or even more , the main point to remember is the heavier you make it , the more force you will need to move it all and then it all falls apart .
is this for only your own use as a hobby or are you looking at building many slot tracks , as this will indeed have a bearing on the way to move forward
stepper motors are the cheaper option , although for reliability i would forgo the tb6560's as a reliable platform , although it may well get you started for the basics , as you progress you will find a better route .
what engineering experience do you guy's have and what tools have you available ?
as this will seriously limit you on the type of machine you can build i presume you mean 1200mm x 800mm ( 4 x 3 )
and also what garage or room do you have to place all this in .. it's suprising how much room they take up , especialy whilst building
i ask these questions to enable more correctly the answers to your main points
all will become clear as i progress your questions
plans etc for this type of machine are plentyfull , some are good , some are darn right dangerous and will just bleed your money
The following user(s) said Thank You: petekaner
- petekaner
01 Aug 2013 01:09 #37302
by petekaner
Replied by petekaner on topic [NEWBIE] Advises creating a cnc wood roter
thanks a lot for the quick reply cncbasher
A hobby, there might be some chances for selling some stuff done with it but not in a professional way, more like "hey i would love to have one circuit done with this, can you sell me one?".
I'm a php developer and I also have linux experience. So computer stuff goes on my side. My brother has strong electronic knowledge and he's also a handyman (and I'm kind of too). Tools: we have everything we need I think: every kind of saws to build the bench, soldiering machine (I don't know if that's the name in english), dremels, drillers, etc etc. We also have tons of space, we live (well my brother, where the thing is going to be made) in the country side. Space is not a problem.
yes, sorry
uoooouuu where that money goes? you say tb6560 its not very reliable but... for something so simple (it doesn't need to be extremely precise, its just draw a 3,5mm slot in mdf) i think it will do. Are the motors so expensive? wich ones would you recommend?depending on your available cash flow , this will not be a cheap fix , expect something in the order of $3,000 - $4,000
- cncbasher
01 Aug 2013 02:00 #37303
by cncbasher
you would probably find just drawing the line freehand and routing it would be far cheaper for such a simple job .
but to answer your question , your probably looking at a guess Electronics 400 -500 Euro , if you use wood as a base of the machine perhaps another 400 -600 Euro , then the cost of the router
etc , the construction of the machine would need to be substantial to withold flex in the gantry and the forces involved against the cutter etc , they are not trivial by any means .
you then need to be able to have some sort of bearings the cheap way is with skate ball bearings and threaded rod etc so add to the above another 100 - 150 Euro
and i'm probably still on the lower cost side .
and you still have a machine that will move and have backlash in the mechanics .
doing this properly with linear bearings , ballscrews will easily treble the cost ..
if you want to look at some plans to get an idea of whats needed send me a pm and i'll forward you a few links that will help
then we can answer specific questions as you work your way through .
the tb6560 is a low cost board which unfortunatly is fraught with being under powered ,if you search the forums you will see many modifications and problems associated with them .
but for a budget start it will get you going , but expect it to fail and be replaced at some time
- petekaner
01 Aug 2013 02:18 #37304
by petekaner
but we started to though about a cnc machine and we got into it
About what you sai about the wood... 400-600 euros. I think we can do it for less than 100, after all we only need a 20mm MDF 1200x800mm and the structure. The thing is... this doesn't need to be extremely robust, the router cuts the mdf just like butter. If you take a look at the picture above and notice where the circuit stands, thats exactly where I routed the slot
Anyway I'd love to do this in the most proper way possible, I send you a PM for those links
thanks a lot
Yeah, I know, that's we are doing right now, here's the last rally circuit I've done (scenery on his way):you would probably find just drawing the line freehand and routing it would be far cheaper for such a simple job .
Time to create page: 0.070 seconds
