Sourcing Stepper Motors & Drivers, Measuring Spind
06 Nov 2013 20:59 #40582 by andypugh
So if I make up an aluminium disk like and set up a light gate and make sure I don't cut threads over a certain speed then that's all I really need to do correct? Would I need some kind of index pulse for cutting threads if it's going to take multiple passes?
Yes, you need index too.
You can use _only_ index and hope that the spindle speed doesn't change much during the cut. This is probably a safe bet with a 10hp lathe and a 14" chuck, less so with a Sherline. The encoder module has a "position-interpolated" pin which outputs a smoothed position between pulses.
Otherwise you need a pulse and an index sensor (typically you make one slot deeper and push the index sensor deeper into mesh)
