Bridgeport Boss 9 R2E4 convertion
12 years 8 months ago #44106 by TheWylieStCoyote
I resonantly acquired a Bridgeport boss 9 R2E4 series 1 CNC mill made in 1985. The controller is died but still in very good mechanical shape. The machine has 3 DC servos, coolant and mist systems, automatic oilier and a bunch of other systems. I am starting the conversion to using LinuxCNC and thought others would like to see this. I am I know that this has been done before and how it is done has been documented, but though I could show what I am doing and maybe get some help in the process.
Goals (kind of in order):
1. Convert this machine to run LinuxCNC
2. Use as many components on the machine as reasonable
3. Do this on a small budget
4. Do this conversion as painlessly as reasonable
5. Convert the spindle drive to use a VFD
6. Possibly add rigid taping by adding spindle encoder
What I have and have done: I have the machine moved into my garage and connected to 3 phase power by means of a rotary phase converter, this is how I know the original controller is died. I have the control computer build less the hard drive (in the mail, 60GB SSD), also the mesa card(s). This is the first part that I could use help with, I was thinking of use a 5i23, 7i33, and 7i37 or maybe 6i25 and 7i77, thoughts?
12 years 8 months ago #44107 by cncbasher
go with the 5i25 and 7i77 addon and a second general i/o card , as the servo drivers are 10v analog input this will make it easy going for you
12 years 8 months ago #44109 by TheWylieStCoyote
My concern was the limited number of IO of the 5i25 at only 34 vs the 5i23 with 72. This is not going to be a limiting factor?
12 years 8 months ago #44114 by cncbasher
no i agree , i was just looking from the other perspective of using the newer range of cards , with the smart serial for extra inputs , such as the 7I73
with the 7I77 you will at least have a VFD 10V analog output for spindle with fwd/rev outputs already .
either way at least your spoilt for choice
12 years 8 months ago #44117 by TheWylieStCoyote
I was not aware they had any thing like the serial connection in the LinuxCNC support, I thought there would be a bit of a buffering problem there. Very good to know. What about the 6i25 then?
12 years 8 months ago #44120 by cncbasher
yes the 6i25 is supported , it shows as a 5i25 and is identical
Time to create page: 0.107 seconds
