Fanuc AC Spindle and DC servos with geckos
- sgsracing
09 Mar 2014 07:40 #44589
by sgsracing
Replied by sgsracing on topic Fanuc AC Spindle and DC servos with geckos
Wonderful! Thank you! Makes me wonder can I use a normal VFD and still do Rigid Taping? Or do I need a CNC type drive like the Fanuc. Seems to me this can be done a lot more cost effectively with a different brand VFD. Thank you for your help thus far!
The following user(s) said Thank You: emcPT
- jmelson
- Thank you received: 158
09 Mar 2014 08:18 #44590
by jmelson
important, although having an analog speed control is good as it allows the spindle to be more
gently slowed during the reverse. I have a Bridgeport with typical AC motor and a plain
VFD. I did put in a filter HAL component to slow down the speed change, and it works
fine. Adding the spindle encoder to the Bridgeport head was the toughest part of the job.
Jon
Replied by jmelson on topic Fanuc AC Spindle and DC servos with geckos
You need a spindle encoder with index signal to do rigid tapping. The spindle drive is not terriblyWonderful! Thank you! Makes me wonder can I use a normal VFD and still do Rigid Taping? Or do I need a CNC type drive like the Fanuc. Seems to me this can be done a lot more cost effectively with a different brand VFD. Thank you for your help thus far!
Jon
The following user(s) said Thank You: sgsracing
- BigJohnT
- Thank you received: 1176
09 Mar 2014 20:01 #44596
by BigJohnT
I use an Automation Direct GS2 VFD on my BP with and encoder and the original AC motor to rigid tap. In my case the spindle is kwik switch so it was dead easy to add the encoder with no drawbar in the way. LinuxCNC has a GS2 component that uses modbus to control the VFD.
JT
Replied by BigJohnT on topic Fanuc AC Spindle and DC servos with geckos
JT
- sgsracing
09 Mar 2014 21:47 #44600
by sgsracing
Now we are talking! I had never considered keeping my old 5HP Ac motor and just adding an encoder ( and a VFD Provided I have an inverter duty motor..). I may still upgrade but knowing its an option to keep it is great! I have read about the GS2 component. in Linuxcnc but it didnt resonate with me! Now I will pay a little more attention as I know what it's about! If I dont use the GS2 component, and I use a AC Servo / Driver that has 0-10v analog where do I set that up in Linuxcnc? This is all wonderful stuff its all starting to come together now! Thank you all!
JT
- jmelson
10 Mar 2014 00:04 #44605
by jmelson
donmw the reversing using a HAL component so the Z axis could keep up.
Don't worry about the "inverter duty" thing. I've been running stock motors on
my Bridgeport and lathe for years with VFDs. They ARE, however, dual-voltage
motors, rated for 240 or 480 V. So, they may have slightly heavier insulation
than would be found on a 240 V only motor.
Jon
You probably need the VFD, as it can make a more gradual reverse. I had to slowand a VFD Provided I have an inverter duty motor..).
Jon
- sgsracing
10 Mar 2014 01:53 #44607
by sgsracing
Great! So If Im getting this all, I can:
- do rigid taping with my existing motor (inverter duty preferred but not mandatory) as long as I add an encoder.
-I can use a GS2 VFD and still be able to reverse the motor.
What would be the difference then to having a "AC Servo" vs a normal motor with VFD. What would be the benefits of using a servo. I get that keeping what I have has a huge cost benefit. but am I loosing performance? Thanks again for all the help its clearing things up BIG TIME!
- jmelson
10 Mar 2014 03:10 #44612
by jmelson
tool changes and to be used as a C axis. This is hot stuff on lathes for live tooling,
but has limited need on a mill. Some machines with CAT and BT tooling need
the spindle oriented pretty accurately for the spindle's drive dogs to engage
the toolholder's slots. Older machines had a sensor and a shot pin that
would do this, newer machines do it all with the spindle servo.
SOME servo drives may have a wider torque range without gear changes, but that
is basically just a higher HP motor than is needed at high speed, to guarantee
you have sufficient torque for low-speed work. That allows them to maybe
only have a 2-speed gearbox instead of multiple speeds.
Jon
The only real advantage to a servo spindle is it can lock to a particular position forGreat! So If Im getting this all, I can:
Jon
- Thank you received: 5214
10 Mar 2014 03:17 #44613
Replied by PCW on topic Fanuc AC Spindle and DC servos with geckos
Since LinuxCNC "gears" the axis motion to the spindle rotation via the encoder
feedback, I dont think much is gained with a AC servo on the spindle vs a VFD/induction motor.
Some exceptions might be applications where quick spindle orientation/positioning is
needed, and maybe for tapping blind holes where the AC servos faster reversing would help.
- Thank you received: 4967
10 Mar 2014 20:08 - 10 Mar 2014 20:14 #44622
What is wrong with Resolvers? I have resolvers on my mill, running with LinuxCNC.
Both Pico and Mesa have resolver interfaces, my particular machine is running with a 5i23
store.mesanet.com/index.php?route=produc...=83_85&product_id=65
and a 7i49
store.mesanet.com/index.php?route=produc...83_86&product_id=101
Both fully-supported by LinuxCNCand will drive the Geckos.
[Edit] Oops, Gecko G320 is step/dir control (an abomination).
You could consider Granite, Pico or Mesa servo drives instead.
Replied by andypugh on topic Fanuc AC Spindle and DC servos with geckos
I am rebuilding a DAH LIH MC3 it has a 5hp AC motor and DC servos with resolvers for the xyz axis. I will upgrade the servos to newer servos with encoders and drive them with geckos.
and a 7i49
Last edit: 10 Mar 2014 20:14 by andypugh.
10 Mar 2014 20:20 - 10 Mar 2014 20:23 #44623
Just for variety. I run my spindle from a Hitachi VFD and rigid tap. But I added a Resolver to my spindle, not an encoder.
Works beautifully for rigid tapping, and even for a slightly unconventional variant thereof (The link was _meant_ to start at 59 seconds in)
Last edit: 10 Mar 2014 20:23 by andypugh.
Time to create page: 0.101 seconds
