Binary Fan out HAL function?
- WRC_CNC
30 Mar 2014 04:57 #45388
by WRC_CNC
Binary Fan out HAL function? was created by WRC_CNC
Is there such a thing?
I want to give a PLC the tool number in BCD for tool change purposes.
So I need to take the tool number, Convert to BCD, Then output that on 4 outputs.
- Thank you received: 5018
30 Mar 2014 07:16 #45396
I don't think there is, which does seem something of an oversight.
In Master there is "mux_generic" and 4 of those with bit-outputs could be configured to do the job.
"weighted_sum" solves the inverse problem.
It would be a very easy component to write, have a look at the comp docs:
www.linuxcnc.org/docs/devel/html/hal/comp.html
Might even work (can't test it here)
A component for inclusion in the project would need docs and a way to specify number of bits, but you can probably sudo comp --install in2bit.comp and get what you need.
Replied by andypugh on topic Binary Fan out HAL function?
component int2bit;
pin out bit pin0;
pin out bit pin1;
pin out bit pin2;
pin out bit pin3;
pin in bit in;
pin0 = in&0x01;
pin1 = in&0x02;
pin2 = in&0x04;
pin3 = in&0x08;
01 Apr 2014 03:58 #45468
I asked on the IRC and a suggestion was that you can do this in Classic Ladder, which is the software PLC that is built-in to LinuxCNC.
In fact, you might be able to do away with the external PLC.
www.linuxcnc.org/docs/html/ladder/ladder_intro.html
- WRC_CNC
01 Apr 2014 06:34 #45473
by WRC_CNC
Replied by WRC_CNC on topic Binary Fan out HAL function?
Ok, thanks for checking into that!,
I just wanted an external PLC because the machine im working on has like 45 inputs and 16 outs,
Most of these IO is not needed by linuxcnc so I was going to program it in a PLC, Plus I understand PLC's
I cant say that about LinuxCNC yet
Thanks for the help, I will read up on the PLC BFO
01 Apr 2014 16:41 #45483
I will probably add the function you first asked for in the next few days anyway.
I understand PLC's
I cant say that about LinuxCNC yetO
03 Apr 2014 05:10 #45517
The new function is now pushed to V2.5.
You would need to update tomorrow to get it, following the instructions here:
buildbot.linuxcnc.org
- WRC_CNC
03 Apr 2014 05:53 #45522
by WRC_CNC
Cool, Thanks I'll use it.
Is this the structure then:
component int2bit;
pin out bit pin0;
pin out bit pin1;
pin out bit pin2;
pin out bit pin3;
pin in bit in;
component int2bit;
pin out bit pin0;
pin out bit pin1;
pin out bit pin2;
pin out bit pin3;
pin in bit in;
03 Apr 2014 06:00 #45523
Not quite.
The entirety of the file is here:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...fs/heads/v2.5_branch
Not quite.
03 Apr 2014 17:50 #45533
It has now appeared in the docs, so presumably the component itself is now available if you get the very latest release from the buildbot.
manual page: www.linuxcnc.org/docs/html/man/man9/bitslice.9.html
Note that tool number is a signed integer, and this component takes an unsigned integer, so usage would be.
(for a parallel port, edit the output pins to suit what you are using)
#load one bitslice with 4 outputs
loadrt bitslice count=1 personality=4
#load a convertor
loadrt conv_s32_u32 count=1
#add them to the servo thread so that they actually do something
addf bitslice.0 servo-thread
addf conv_s32_u32.0 servo-thread
#connect it up
net toolnumber iocontrol.0.tool-prep-number => conv_s32_u32.0.in
net unsigned-toolnumber conv_s32_u32.0.out => bitslice.0.in
net bit0 bitslice.0.out-00 => parport.0.pin-00-out
net bit1 bitslice.0.out-01 => parport.0.pin-01-out
net bit2 bitslice.0.out-02 => parport.0.pin-02-out
net bit3 bitslice.0.out-03 => parport.0.pin-03-out
Time to create page: 0.093 seconds
