THC problem
13 Apr 2014 01:51 #45892 by Rick G
Replied by Rick G on topic THC problem
In hal pin the thv.volts is 0,65..V in the case of 0V input
In this case adjust the Offset to get 0 volts which should also bring the 21 volt at 20 closer to correct.
Test 1: volt setting is 135V, Velocity tolerance 5, Volt tolerance 1
Result: head is crashed into the plate, thc.volts is changed betwen 100-115V, thc.zpos-out is below -30 after a 100mm cutting.
Test 2: volt setting is 100V, Velocity tolerance 5, Volt tolerance 1
Result: head is rised, thc.volts is changed betwen 120-136V,
This seems to indicate that the THC is working but the correction direction is in the wrong direction.
Rick G
13 Apr 2014 13:43 #45902 by Rick G
Also in your testing for the THC to make a correction it needs signals that...
The torch is turned on.
The arc transfer / arc O.K. is on.
The THC is enabled.
The velocity is within tolerance.
The torch voltage is out of tolerance.
Rick G
26 Apr 2014 19:35 #46334 by Rick G
Did you get this sorted out?
Rick G
01 Jul 2014 17:38 #48363 by bokorugro_111
Replied by bokorugro_111 on topic THC problem
Hello!
Sorry, but We had to hold up this project.
Of course we simmulated all the needed signal.
I do not have any other idea.
Thanks,
Csaba
01 Jul 2014 20:04 #48364 by PCW
Replied by PCW on topic THC problem
As Rick G said its looks like the correction direction is wrong.
If this is wrong Z will aways "runaway" from the setpoint
instead of following it when the THC is enabled
01 Jul 2014 20:08 #48365 by bokorugro_111
How can I modified the direction of the THC correction?
01 Jul 2014 20:34 #48366 by PCW
Its easy enough to fix the feedback direction (inverting the Direction pin is a simple way)
but this will also reverse the Z commanded position from Motion.
This may work:
Reverse the Z direction by inverting the direction pin (so feedback is correct)
This can be done in HAL
Reverse the Z axis scale (OUTPUT_SCALE) so Motion is correct
I would set the correction velocity very slow for testing, then verify
that if the setpoint voltage is higher than the torch voltage, the torch moves up
and vice versa
02 Jul 2014 13:35 #48379 by sneci
Replied by sneci on topic THC problem
Sorry I am not a professional user. Can You detailed it how can I do that?
02 Jul 2014 15:38 #48382 by Rick G
You could also try changing the sign of
thc.correction-vel
thc.correction-vel float rw
The amount of change in user units per period to move Z to correct
Rick G
04 Jul 2014 18:06 #48427 by bokorugro_111
Hello!
I tied to cut whith the changed thc.correction-vel parameter (it was 0.01 and modified -0.01).
Cutting velocity is betveen 2400-1680mm/min.
The THC settings:
Vel tolerance: 1500
volt: 79
volts tolerance: 1
The correction direction is changed, but result is the same that it was.
The head is only rised or only sinked.
I wached the arc volt in the hal config. It seems good (It was neer to the value given by the Hypertherm).
Can be that the correction velocity is too slow?
Thanks,
Csaba
Time to create page: 0.217 seconds
