Homemade CNC Router for Oxy and Plasma
- emcPT
- Thank you received: 139
08 Jun 2014 12:58 #47785
by emcPT
Replied by emcPT on topic Homemade CNC Router for Oxy and Plasma
Only the mechanics will consume more than 1250€ if you will make a new machine.
The following user(s) said Thank You: nmnbento
- Livemill
08 Jun 2014 14:44 #47787
by Livemill
Replied by Livemill on topic Homemade CNC Router for Oxy and Plasma
that amount of money will not retch a 60x90 cm mashine
lets calculate realy basics
PLASMA hypertherm 1500Euro or a bad one like s-plasma 45 at 350euro it will work but!!
the driver stages at 100Euro etch 4times 400Eur
www.pro-tos.de/shop/Endstufen/Endstufe-H...-M880A-7-8A-80V.html
THE CHINA pices may give you a cut in cost but also a significant cut in SPEED
the steppers at 100 etch 4times 400Eur
www.pro-tos.de/shop/Schrittmotoren/Schri...H2120-42-8-8-Nm.html
at least 2 80V powersupples 80euros etch 160Eur
www.pro-tos.de/shop/Netzteile/Netzteil-SP-75V-5A.html
the board best to go is mesa 5i25/7i76 250Eur but a parport will give yo about 2500mm/min at 50Eur
for all electronic components you need to calculate on 1k Eur
the worm will aso add another 400euros you can shoot on ebay things for maybe 250 eur
LOW cost means no precision not usable for real work on that mashine size
PLEASE LOG in to our IRC channel so we can talk live on that
- nmnbento
08 Jun 2014 20:39 #47789
by nmnbento
Thanks for the feedback.
I not explained very well.
The €1250 is just for the drivers, motors, encoders and power supplies and maybe some software
I all read have the plasma, I have 3 plasmas
I know that I will spend about €4500 to €5000 in the machine.
Any one have a good setup/diagram for the machine??
Replied by nmnbento on topic Homemade CNC Router for Oxy and Plasma
- emcPT
08 Jun 2014 21:55 #47791
by emcPT
If you have the plasma (plasma source and mechanics made), you need to inform what is the plasma source, weight of the gantry, and so on to calculate the working speed that the machine needs to get so that a proper motor configuration can be found.
If the plasma machine was already a CNC machine, looking at the current motors can help a lot of calculations, and in that case, why not using the current motors?
- nmnbento
09 Jun 2014 16:28 #47800
by nmnbento
Hi!
I don't want use the body of the old machine and motor or any thing else, I want make a new one, using linear guides best motors and new hardware.
I also want use one pc with the linux cnc.
So I have one Thermal Dynamics Auto-Cut 200, one SAF Zipmatic 738 and one SAF Zip 5.
The gantry should weigh more or less 300kg.
Hi!
- emcPT
09 Jun 2014 17:48 #47803
by emcPT
For start you need (at least this is my recommendation, others are also possible, but this configuration is proved):
Mesa 5i25
Mesa 7i77
Servo motors
Servo drives
You can also have a THC (automatic control of the torch heigh).
Please check www.eusurplus.com for some prices. Store is in Portugal.
But my recommendation is to look at your current motors and see their specifications. That could help you deciding the new motors.
Mesa 5i25
Mesa 7i77
Servo motors
Servo drives
Time to create page: 0.486 seconds
