Controlling A DC Brushed Motor
  • russtuff
  • russtuff's Avatar Topic Author
  • Senior Member
  • Senior Member
06 Aug 2014 08:33 #49548 by russtuff
Controlling A DC Brushed Motor was created by russtuff
Hello!
I have a small milling machine and will be swapping to a 3HP DC motor, with a new controller (which takes 220Vac instead of the stock motor's 110Vac). The controller is a KBMM-225D, which you can see here: www.galco.com/buy/KB-Electronics/KBMM-22...C6_b8CFWho7Aod4TYAVw
I have been using LinuxCNC for a year or two but have never done any customizing, so I am seeking guidance on how to proceed with a few of my goals for this new motor. I am not looking for you guys to solve these problems for me, but am hoping some of you can point me in the right direction.
1. I would like LinuxCNC to know the spindle RPM. From the factory, there is an index ring with 16 slots (16 pulses/rev) that are read by a sensor for the RPM readout. I'm not sure if this ring can be used, or if I need a 1 pulse/rev ring for the software. Does this signal go right to the break out board (mine is a C11)?
2. If the spindle RPM drops (even something like 20%) due to sudden load (crash) I would like LinuxCNC to ESTOP.
3. Have LinuxCNC control the on/off of the spindle, and set the spindle speed. The KBMM says "An isolated 0 - 9 Volt DC analog signal input can be used to control motor speed in lieu of the Main Speed Potentiometer" so I assume I should be able to get this working.
I appreciate any help you guys can offer. If you have used the KBMM for any of this, even better :)
06 Aug 2014 11:39 #49550 by jmelson
Replied by jmelson on topic Controlling A DC Brushed Motor
Hello!
The main warning is the KB motor drives are NOT isolated from the mains. So, anything that sends a speed control
signal to the KB drive needs to be isolated. You can probably build an isolator with an optocoupler and
a few components. Then, you'd have your CNC control send a pulse width modulated signal to the
optocoupler.
Jon
  • russtuff
  • Senior Member
  • Senior Member
06 Aug 2014 11:47 - 06 Aug 2014 11:49 #49551 by russtuff
Replied by russtuff on topic Controlling A DC Brushed Motor
Thanks for the heads up, I'll start doing some research.
Last edit: 06 Aug 2014 11:49 by russtuff.
  • russtuff
  • Senior Member
  • Senior Member
06 Aug 2014 14:50 #49556 by russtuff
Well I've been doing some reading and am realizing that it may be a pain to get my C11 breakout board to talk to the KBMM board. I think I'll skip that part for now, but I would still like to get LinuxCNC to read the spindle so I can have an onscreen tach.
  • russtuff
  • Senior Member
  • Senior Member
07 Aug 2014 07:44 #49570 by russtuff
This thread is turning into a bit of a one man show, but it looks like I can use the CNC4PC C6 to control the spindle speed (and it's optoisolated) and the C3 to send a tachometer signal to my C11 breakout board.
Thanks Rus!
10 Aug 2014 18:29 #49651 by andypugh
Replied by andypugh on topic Controlling A DC Brushed Motor
Mesa have a device that might help:
store.mesanet.com/index.php?route=produc...spinx&product_id=205
Basically an isolated potentiometer replacement.
The onscreen Tach should be fairly trivial. Multiple slots per rev is no problem, you just need to set the encoder scale correctly. With only a single slot you would need to "setp encoder.N.counter-mode 1".
An index slot would help if you want to do rigid tapping, but otherwise doesn't add anything.
  • russtuff
  • Senior Member
  • Senior Member
12 Aug 2014 02:05 #49717 by russtuff
Thanks, that's a great link!
I haven't even considered rigid tapping, so I'll look into that. Thanks again.
Time to create page: 0.070 seconds
