School me on linux cnc based 3d printers.
- Alloy Craft
25 Sep 2014 09:01 #51552
by Alloy Craft
School me on linux cnc based 3d printers. was created by Alloy Craft
I was thinking about building a multipurpose XYZ table capable of both 3d printing as well as laser cutting ( 100 watt). The laser side seems simple enough, However I am not quite sure what components of Linux cnc are capable of doing the 3d printing part. I know I will need some way to drive the extruder and extruder heater, but I'm not sure if I need feedback from these components in linux? My axis drives will be analog imput servos, not sure about the extruder though? Would a small servo do, or is a stepper better suited for this job? Also since I am using analog servos I'm not sure what driver boards would work well, mesa, reprap, beagle bone?
Components that I have:
24x24 in XY axis table with limits and homes prewired.
3 sets of Analog input yaskawa servo motors + drives
Components that I think I need
ebay extruder head
control cards, mesa, beagle bone, reprap, ect?
ebay laser tube
laser power supply
laser liquid heat exchanger
laser colminator
Thanks.
ebay extruder head
ebay laser tube
laser power supply
laser colminator
Thanks.
- ArcEye
- Thank you received: 758
25 Sep 2014 14:44 #51556
by ArcEye
Replied by ArcEye on topic School me on linux cnc based 3d printers.
Hi
I would suggest that you ask on MachineKit forum
groups.google.com/forum/#!forum/machinekit
3D printing is pretty much all that anyone on there does and there is a lot of expertise with that and laser.
On a rig this size, especially If you are using servos, I can see no point in increasing your complexity 90%, by trying to use a low power ARM board to drive it.
Just use a mesa combo on a normal PC, it is not as if you are going to be trying to save space.
Time to create page: 0.153 seconds
