emcoturn 140
- spesmek
30 Sep 2014 02:44 #51670
by spesmek
emcoturn 140 was created by spesmek
Hello i have a emcoturn 140 and are in the process of changing to linuxcnc controll. I vant to use the stepper motors and drives, but i dont know anything about step timing for theese drives. Does anyone have a sugestion on how i should configure linuxcnc and step-timing
Best regards Bjorn.
Best regards Bjorn.
- ArcEye
- Thank you received: 758
30 Sep 2014 15:10 #51679
by ArcEye
Replied by ArcEye on topic emcoturn 140
Hi
See this thread for starters
www.linuxcnc.org/index.php/english/forum...upgrade?limitstart=0
The 5 phase steppers are discussed and Jon has suggestions for Vextra drivers that can be used to power them.
- spesmek
30 Sep 2014 23:19 #51692
by spesmek
Replied by spesmek on topic emcoturn 140
Yes thats an option, but it seems like the emco drives take step and dir signals, so i consider to keep them. Is it possible to do some kind of test to figure out how long a step has to be high, and how long before next step the dir has to be set for the motor to change direction. There is not much info about the emco 5ph stepperdrives to find. But i have some connection diagram that show where the step, dir and enable goes.
- Thank you received: 5278
30 Sep 2014 23:48 #51695
Replied by PCW on topic emcoturn 140
There is very little disadvantage to making the setup and hold times too long.
Making the step time and step space time too long only limit your maximum step rate.
So knowing the drives specs is really not all that important for initial testing
Starting with a very conservative 50usec/50usec for setup and hold times and 20usec/20usec for steptime/stepspace
will work with most drives and you can reduce the steptime/stepspace if they are the limiting factor in getting to
your maximum possible rapid rate
- spesmek
01 Oct 2014 02:36 #51698
by spesmek
Ok, i will go on testing then. It is my first lathe so it will be fun too se how linuxcnc works for this. I have a mill and a plasmatable runningn linuxcnc that we use in my shop, and have been using for years. I got my first comercial mill with fagor controll a year ago. It's a nice machine but i am actualy finding things that seems to be a bit complicated to do with the fagor. That i know would have been easy with linuxcnc. I love the software, it is realy impressive.
Best regards Bjorn.
Best regards Bjorn.
