Basic Setup 3 Axis CNC Router - Recommendations
- Meister_Petz
13 Oct 2014 20:26 #52020
by Meister_Petz
Basic Setup 3 Axis CNC Router - Recommendations was created by Meister_Petz
often, I would like to cut out my digital drawings (dxf,...) using a cnc router instead of a saw
After watching some youtube videos, I found out that CNC Routers can be built. Unfortunately I'm not quite sure, what hardware is necessary between the whole mechanic part (table, axis, ... ) and linuxcnc.
Probably there is a stepper motor for each axis. But what do I need in addtion?
Is that enough?
www.ebay.de/itm/25141118
Some Data:
Material to be cut: 95% wood, Rest: PVC, Acryl, Alumium (thin sheets)
Accuracy: 1-0,5 mm
Work Piece Maximum Size: 100 cm x 50 cm
Option for a 4th Axis (for rotating zylindric objects)
Speed: I don't care
Router: Makita 700 W router
Price: low
Connector: Preferably USB
Spindle: threaded bar (M10?)
Background Knowledge:
I'm an IT-Guy with severe wood working and metal working skills.
Many Thanks for your help!
Petz
Is that enough?
Some Data:
Accuracy: 1-0,5 mm
Speed: I don't care
Price: low
Petz
- Thank you received: 5278
14 Oct 2014 00:55 #52057
Replied by PCW on topic Basic Setup 3 Axis CNC Router - Recommendations
Linuxcnc does not support USB for motion currently
For a simple router, I would use a parallel port configuration
if you motherboard does not have a parallel port you can add a PCI pr PCIE parallel port add-in card)
The following user(s) said Thank You: Meister_Petz
- Thank you received: 5002
14 Oct 2014 07:29 #52073
I can't see the auction, so don't know what it was for, but consider soemthing like
www.ebay.co.uk/itm/DE-Ship-4Axis-Nema23-...achine-/321550370700
as a starting point.
In practice you probably won't finish up with that, but it will get you started. I bought one of those kits, and the PSU and one motor survive
But in the process I learned what I actually needed, and that kit did work, I just got more ambitious.
USB is a "No" for linuxCNC. it doesn't fit the LinuxCNC control model. (USB can take a few mS to transmit data, LinuxCNC is the controller, and relies on <1mS response times from hardware.
PCI, Parallel port and Ethernet all manage latency in the region of a few uS.
Replied by andypugh on topic Basic Setup 3 Axis CNC Router - Recommendations
- Meister_Petz
14 Oct 2014 16:27 #52078
by Meister_Petz
Replied by Meister_Petz on topic Basic Setup 3 Axis CNC Router - Recommendations
perfect.. the auction was deleted...
USB:
unfortunately (or fortunately) all my hardware is Apple. So would it be possible to use a usb to parallel adapter and run lunxcnc in vmware fusion? If not... well I have to change to the dark side
Stepper Motor:
is a nema 23 powerful enough to support a 100 cm threaded bar (M10-M12)
Thanks for the fast answers
Petz
USB:
Stepper Motor:
Petz
- cncbasher
- Thank you received: 288
14 Oct 2014 16:35 #52079
by cncbasher
Replied by cncbasher on topic Basic Setup 3 Axis CNC Router - Recommendations
linuxcnc needs to run real time , so any virtual machines wont work ,
usb is out as is a usb to parallel adaptor
nema 23 motors should be fine , but you dont mention what model
it's more down to the power supply you use , and combination of stepper drivers
you'll find you'll get a better result with seperate drivers rather than the all on one board type
- Meister_Petz
14 Oct 2014 16:52 #52080
by Meister_Petz
So a PC will be found!
I was looking at something lihe this (for example): www.ebay.de/itm/271630907966
3x Nema23 Stepper Motor 57BYGH627 270oz-in 76mm 3A 4-Lead SINGLE SHAFT
3x Stepper Driver with 4.2A DQ542MA replacing M542
Power Supply for 350W,36VDC
DB25 Breakout Board
should this fit my requirements (for the beginning)?
Many Thanks
DB25 Breakout Board
Many Thanks
14 Oct 2014 16:56 #52081
I was in the same situation when I started.
It doesn't make any sense to try to run your CNC machine with the same computer as you use for your general purpose computing.
Because OSX is a Unix, it plays well with Linux. I often ssh into my CNC controllers using remote X-sessions from the iMac, for example. (and my CNC machines nfs mount a folder on the Mac to pick up CNC files).
Find a cheap PC with a parallel port to be your dedicated CNC controller, and install the LinuxCNC live-CD on it.
I run various versions of LinuxCNC under VMware, but only for testing, not for machine control. Lat6ency in VMware is incredibly bad, it could never run a CNC machine, not even one of the buffered Mach3-compatible controllers.
In principle you could dual-boot the Mac into Linux and use an Ethernet-interfaced controller. The Mesa 7i80 for example, but this would be extremely experimental. (Hmm, I might try that, just for fun
14 Oct 2014 17:00 #52082
Yes, it should. The fact that it is three separate drives is a big plus-point.
what sort of machine do you want to control?
- Meister_Petz
14 Oct 2014 17:54 - 14 Oct 2014 18:11 #52083
by Meister_Petz
The frame will probably be aluminium Profile or MDF or a combination.
The axis will be run over ball-bearings
The router will be a Maktia 700W (RT0700)
Is that what you meant?
The machine is not built yet.what sort of machine do you want to control?
Last edit: 14 Oct 2014 18:11 by Meister_Petz.
14 Oct 2014 18:36 #52084
Yes.
A lot of those designs use 4 motors. Just something to bear in mind.
Yes.
Time to create page: 0.227 seconds
