Yaskawa CPCR-MR052 G Servopack inputs. HELP!!!
9 years 9 months ago #85867 by nicknackks
Cory,
Do you still have information about interfacing with these drives? Mine have the honda style connectors and I'm about to undertake a retrofit and want find out as much as I can before I start ordering things.
9 years 9 months ago #86105 by JR1050
On another thread I listed the pin to pin numbers from the honda side to the drive side. The Mx1manual lists the signals on the same connector On the cpo2 board. The manual is on line, you want the mx1/lx1 interconnect manual.
6 years 3 months ago - 6 years 3 months ago #173372 by rootboy
Sorry to wake this slumbering thread, but I had the same problem and I reached out to Mr. Sato and he provided me with a drawing of the "G" revision drive.
I've responded to my own thread with the file, so rather than re-upload it you can find it here:
forum.linuxcnc.org/30-cnc-machines/39444...4-wiring-help#173370
Edit: Added a QCAD drawing of the pertinent stuff. Pertinent to me at least. PDF included.
Take a look at the 1CN and 2CN connectors. If they had been labeled on the board, they would start with 1 at top left, and go clockwise to 20 on the bottom left.
And Mr. Sato's drawing covers the -052 "G" revision of the drive. To the best of my knowledge, the difference between my -054 G and a -052 G is minimal. The connections should be the same for each.
Last edit: 6 years 3 months ago by rootboy. Reason: Updated message to point out additional available information.
6 years 3 months ago #173442 by kt600v
I think most of conections are similar , hope this helps too.
6 years 3 months ago #173704 by JR1050
Good job obtaining the drawings!! For those of you are are still using these drives, I have two working top boards for sale pretty cheap. Yaskawa no longer repairs them, parts are longer available. These came out of a Matsuura which had a bad Y board. I’m keeping the original Yasnac control for now and have already replaced them with different drives. Pm me if you can use them.
4 years 7 months ago #238565 by dmautomacion
can you send me the excel table?
I have a MORI SEIKI SL2B and i want to retrofit it.
Time to create page: 0.457 seconds
