Laser Engraving
16 Nov 2015 16:04 #65331 by cncbasher
Replied by cncbasher on topic Laser Engraving
i dont see a problem ,
i'll look at the setup you have later today once i arrive home . so don't Panic !
16 Nov 2015 18:10 #65335 by Micromet
Replied by Micromet on topic Laser Engraving
Hi Andy,
Yes - I had thought about using Z-axis positioning to moderate the laser output - but I came to the conclusion that (a) the change in intensity would be very small over the Z-height range of 100mm; (b) you couldn't move the Z-axis fast enough when going from dark highly burnt areas to light unburnt areas (e.g. inside/outside strong shadows); and (c) it would change the focus of the laser leading to blurring of the burned image - analogous to increasing the pixel size within the image from small concentrated pixel burns to large lightly burned pixels - although that might be an artistic option that could work.
16 Nov 2015 18:37 #65337 by andypugh
Replied by andypugh on topic Laser Engraving
HYes - I had thought about using Z-axis positioning to moderate the laser output - but I came to the conclusion that (a) the change in intensity would be very small over the Z-height range of 100mm;
Some confusion here...
Image-to-Gcode outputs G-code where Z height is proportional to black-level. So I don't mean actual physical Z-height but the Z-value output by the G-code, which probably would not be connected to a physical axis at all.
16 Nov 2015 18:42 #65341 by cncbasher
changing z pos does not work , as essentialy you will move out of the focus point of the laser
you need to control the diode for the best performance
Time to create page: 0.087 seconds
