Servo driver selection
10 years 10 months ago #66592 by andypugh
Replied by andypugh on topic Servo driver selection
Gatesy wrote: I did have a look inside one a while, and I seem to remember it was like a glass disc with 4 tracks etched on to it?????
That sounds like the 4-track gray-code, as has been discussed.
10 years 10 months ago #66593 by Gatesy
Replied by Gatesy on topic Servo driver selection
Do these encoders give out a standard encoder output, or is it unique to Fanuc?
10 years 10 months ago #66604 by jmelson
Replied by jmelson on topic Servo driver selection
Gatesy wrote: Do these encoders give out a standard encoder output, or is it unique to Fanuc?
All Fanuc "Red Cap" encoders are proprietary to some degree. The original version had standard AB quadrature plus index, but the commutation signals were proprietary. A later version added battery backup and a position memory to the encoder, so the control could set the home position anywhere, and then when the control was powered up, the encoder could send all the quadrature counts from home to wherever it was at power-off (of the control). This includes the number of full turns from the home position. You did not need to perform a home move sequence each time the control was powered up.
These are called the ABS encoders, and have an extra 2-pin connector on the encoder dust cover. The AB quadrature and index signals on these encoders are industry compatible. They are seen a lot on robots, which can be very hard to home due to the collision risk.
Then, they came up with serial encoders. The problem with quadrature encoders is the count rates get very high when they are moved fast. Some of the latest serial encoders give resolutions of one million counts/rev. If such an encoder is spun at 2000 RPM (33.3 revs/second) then it would give 33.3 million counts/second, which few CNC controls could handle. So, they decided to have the encoder send the absolute position, incuding nuber of turns from home, all the time, rather than the incremental counts. This protocol is totally proprietary.
Jon
10 years 10 months ago #66605 by jmelson
Gatesy wrote:
The numbers on the encoder casings are A860-0308-T112 And they are 2500P
This exact model is not in my cross reference, but it seems like it must be from the first series, and will have the traditional AB and Z signals, and the 4 commutation signals. So, it is not a serial encoder.
Jon
10 years 10 months ago #66650 by Gatesy
Thanks Jon
I have often wondered what the difference is between the different types.
I have found the encoders I have are also listed as A290-0521-V542 incremental pulse coder
10 years 10 months ago #66655 by jmelson
Gatesy wrote: Thanks Jon
Oh, it is BAD!!! They made THOUSANDS of different types of encoders, drives, motors, it is VERY confusing.
Yeah, see, A290 is a "catalog number" which is different from a "reference number". The A860 is the Reference number. I don't have your A290-0521-V542 number in my cross reference. But, I might be able to look it up from the motor number, which also contains the encoder type info.
Jon
Time to create page: 0.922 seconds
