The great cpcr mr052 pin out mystery
- JR1050
- Thank you received: 31
27 Jan 2016 01:38 - 27 Jan 2016 01:41 #69143
by JR1050
The great cpcr mr052 pin out mystery was created by JR1050
Ok, I have to double check this again with my meter. I have an mx1 with these drives. The mx1 connection manual is available on line, it lists the signals on each pin of the 20 pin Honda connector. This is the same as the k drives that use one plug, the signals are mor thoroughly explained in that manual. I have to double check this and I will list each signal/pin at a later date
Plug 2 key sidepin. Mx1 pin
1. - 6
3 - 1
5. - 6
6. - 17
7.- 3
8.- 16
Plug2 non keyed side
1. - 12
3&4 jumpered
9&10. Jumpered
Plug 1 key side
2.- 7
3.- 5
6. - 4
7. - 19
Other side plug 1
2.- 13
You should be able to deduce the signals from the manuals. Again, I have to double check these and the signals appear to be the same as the signals on the first plug of the k drives. Good luck.
1. - 6
3 - 1
5. - 6
6. - 17
7.- 3
8.- 16
1. - 12
3&4 jumpered
9&10. Jumpered
Plug 1 key side
2.- 7
3.- 5
6. - 4
7. - 19
Other side plug 1
2.- 13
Last edit: 27 Jan 2016 01:41 by JR1050.
