Thermwood C40 retrofit
23 Feb 2016 13:39 #70533 by Les91
Thermwood C40 retrofit was created by Les91
Has anyone retrofitted a Thermwood Model C40 router with linux cnc? This machine has Siemens servo system.
01 Mar 2016 09:31 #70863 by ftree
Replied by ftree on topic Thermwood C40 retrofit
I'm thinking about doing the same on a 5 axis Model 67 (2 tables 5'x5'). Maybe we could collaborate.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
02 Mar 2016 07:11 #70902 by andypugh
Replied by andypugh on topic Thermwood C40 retrofit
Do you know what type of command signal the servo drives take?
The conversion is likely to be moderately simple unless the drives take some proprietary serial data format or suchlike.
10 Aug 2025 14:25 #333181 by yadamb
Replied by yadamb on topic Thermwood C40 retrofit
Hi, did you guys end up collaborating? I have. a C67 and am looking to upgrade the controller from the 2011 version it currently is at. At this point thermwood will only offer me a full conversion which is 90k and completely too much money. I have been looking at using Masso or centroid, but im not sure which is worth it if they even are and that's what brought me to Linux. Personally im not extremely knowledgeable on the software side, but hardware im good at and feel relatively confident I can actually continue to use the Siemens drivers motors and board that are currently on the machine. Id love to chat with either of you guys about it if you have a chance.
10 Aug 2025 15:20 #333184 by tommylight
Replied by tommylight on topic Thermwood C40 retrofit
The above has already been replied on the other topic/thread.
