Information spindle & drive Kollmorgen-Cincinnati
  • finemeca
  • finemeca's Avatar Topic Author
  • Visitor
  • Visitor
24 Feb 2016 18:27 #70580 by finemeca
Hello,
We have a machining center Cincinnati Milacron Arrow 750.
The control of the machine is out of service and we will change it.
I am searching information on the spindle motor and drive:
High performance induction motor
Model: 1-604-0006
Serie: 98F286-77
27A 3.7 KW
Kollmorgen Ind or Cincinnati
SPINDLE DRIVE 30AMP VFS5
Model VFS523000203A
Series: 230 / 203AC-042 rev 4.0
Can you give me the technical documentation?
I am searching primarily voltage frequency curve?
Best regards,
Pierre
25 Feb 2016 22:52 #70644 by andypugh
If it is an induction motor then a generic VFD should run it. A modern VFD can probably auto-tune itself, too.
The following user(s) said Thank You: finemeca
Time to create page: 0.072 seconds
