Brither tc-211 new problem
26 Jun 2016 15:21 #76677 by mblaszkiewicz
Brither tc-211 new problem was created by mblaszkiewicz
Hi again everyone.
I have a new problem that just turned up on my machine, probaly an easy fix.
I haven't been on the machine for about 3 weeks, shut it down as usual.
When I went to start it I got to the main window. but when I tried to start it up I got A
" joint 0 on limit switch error"
" joint 1 on limit switch error"
" joint 2 on limit switch error"
I have full power to the 7i76 or 7i77, cant remember which it is. any help would be great.
Thanks again everyone
26 Jun 2016 16:17 #76678 by PCW
Replied by PCW on topic Brither tc-211 new problem
Looks like you need to do some circuit tracing with a voltmeter
Have you lost the common connection to the limit switches?
Do the limit switch outputs change state when you trip the limit switches?
26 Jun 2016 17:45 #76679 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brither tc-211 new problem
Checked voltage and all is good. I went to the hal meter and tried tripping my x-home switch and kept showing false.
The hard limits showed up true
26 Jun 2016 19:41 - 26 Jun 2016 19:44 #76684 by PCW
Did you check the the voltage at the 7I76/77 inputs when you tripped the switches?
(Measure inputs to TB2 pin 8)
Last edit: 26 Jun 2016 19:44 by PCW.
27 Jun 2016 05:24 #76691 by kornphlake79
Replied by kornphlake79 on topic Brither tc-211 new problem
I have had limit switches fail on our brother tc32a machines with the brother CNC control it causes a similar error, non-specific to a particular axis as I recall. Due to the location and potential for contamination the problem usually can be traced to an x axis switch. Test each switch with the wires removed using a multimeter to find the one that isn't working. The switches have a NO and NC contact, make sure to sure to note the connection when you remove the wires, the schematic for one of the limit switches on my tc32a is incorrect, if you have yhe schematic for your machine take this opportunity to check the schematic and make a note on it if it's incorrect.
Time to create page: 0.090 seconds
