Low inductance Nema 34 stepper motors?
- eFalegname
- Thank you received: 30
16 Dec 2016 12:25 #84268
by eFalegname
Low inductance Nema 34 stepper motors? was created by eFalegname
Good morning boys, a month that I'm looking for 4 stepper motors in Europe without success
Someone could show me the right way please? I want to design a dual Y axys CNC Router, and I would need to buy 4x Nema 34 size steoper motors with more less 7A, low inductance 2mH and 6-7 Nm .
And certainly the digital drivers in accordance....
Please help me!
Please help me!
- Thank you received: 4153
16 Dec 2016 19:28 #84283
Replied by rodw on topic Low inductance Nema 34 stepper motors?
- eFalegname
16 Dec 2016 20:35 - 16 Dec 2016 20:46 #84287
by eFalegname
Replied by eFalegname on topic Low inductance Nema 34 stepper motors?
Nema 34 motor from eu.stepperonline:
34HS31-5504S = Inductance 3.5mH±20%(1KHz); Holding Torque 4.5Nm(637oz.in) best inductance but not good torque (I'm planning mill AL, I would need 60v power supply -I have a couple of 48V 600W 12,5A meanwell transformes); Rated Current/phase 5.5A
34HS38-3008S = Inductance 8mH±20%(1KHz) not good for router; Holding Torque 5Nm(708oz.in); Rated Current/phase 3.0A
34HS46-5004D = for me that's huge Inductance value 11mH±20%(1KHz); Holding Torque 8.5Ncm(1204oz.in); Rated Current/phase 5.0A
34HS59-5004S = Holding Torque 13Nm(1841oz.in); Inductance 11mH±20%(1KHz); Rated Current/phase 5.0A
Thank you rodw!
Thank you rodw!
Last edit: 16 Dec 2016 20:46 by eFalegname.
16 Dec 2016 21:52 #84289
Also check their global site. There is a greater range of products. I have also ordered from them. It takes a bit longer as the stock is not local.
- eFalegname
17 Dec 2016 00:24 - 17 Dec 2016 11:53 #84297
by eFalegname
Hi again.
I found this stepper in Italy M1343031 , price 116€ each. I would like to pair them with EM806 Leadshine Drivers price 115€, and I have no clear idea of how to do it because the motor has "8 wires".
Any help will be really apreciated.
Last edit: 17 Dec 2016 11:53 by eFalegname.
- eFalegname
17 Dec 2016 00:33 - 17 Dec 2016 00:40 #84298
by eFalegname
beautiful found about "How to Properly Connect a Stepper Motor to Unipolar or Bipolar Drivers" ...
...then my question is, can I connect the X and Y stepper motors in parallel and Z axis stepper motor in series to my drivers?
Last edit: 17 Dec 2016 00:40 by eFalegname.
- Online
- Thank you received: 7496
17 Dec 2016 08:29 #84311
Replied by tommylight on topic Low inductance Nema 34 stepper motors?
In europe you have Lam Technologies, they have by far the best stepper drives that i have used, and you can find those same drives at discount from Germany. They also have motora, but i never used them, mostly i use Sanyo motors.
- eFalegname
17 Dec 2016 11:45 - 17 Dec 2016 11:59 #84318
by eFalegname
You're right Tommy. I finally bought the Nema 34 Lam Technologies M1343031 steppers 6.8Nm-7.1A-2.2mH, attached the data-sheet of the series for those interested.
For the digital drivers I'm thinking on buying this one: Leadshine EM806
I want to use a couple of Mean Well SE-600-48 as power supply. What do you think?
Last edit: 17 Dec 2016 11:59 by eFalegname.
- Online
17 Dec 2016 12:01 #84319
www.mechapro.de/shop/Schrittmotor-Endstu...t-Endstufe::206.html
I would advise to get those drives, they are more expencive but worth every penny. Do not forget to also get the programmer for them, you can not program them without it and it is just 28 euros.
I have nothing to do with them but i have a lot of their drives on production machines, and the microsteping on them is simply amaizing, making the smothest motor moves i have ever encountered.
- eFalegname
23 Dec 2016 15:33 - 23 Dec 2016 15:38 #84618
by eFalegname
Last edit: 23 Dec 2016 15:38 by eFalegname.
Time to create page: 0.150 seconds
