Press Brake CNC Control & G-Code
8 years 6 months ago #109538 by bymccoy
Maybe, but the page really doesn't seem useful to anybody retrofitting a press brake...
6 years 5 months ago #167569 by alexandrub
I ask if anybody have a diagram or a calculation formula to determinate the y travel . As example : For a 2mm metal mild sheet and 1000 mm long, for a 60deg angle, y travel must be x.xx mm. The travel i assume will be calculated from material is in touch with the punch.
6 years 5 months ago #167578 by bymccoy
In theory you can create tables etc, but in reality it just doesn’t work like that. The super expensive CNC press brakes use laser positioning to dynamically measure the part and stop when the angle is found. You just can’t get that level of repeatability across batches of sheet metal for a start - spring back can vary based on temp or just what mood it’s in.
You would also have to factor the punch radius, the die size, shoulder and angle. Is the bed crowned? Bending a 100mm part requires different crowning compensation compared to 1000mm - and that has to be done per bend.
You just have to do a test and then use that Y for the session, and treat it as a reference for future batches. The closest you can get is to record each Y you use and build a table of your own of actual data.
I’ve found that there’s no repeatable or safe way of zeroing the Y axis or even the punch holders (if they have crowning adjustment). It’s all very manual. You’ll find that any numbers you get are relative and not absolute. You’ll be lucky to even find a way of getting the Y axis to be accurate to the fraction of a mm (which you need), so again, it’s trial and error with setup.
Full automation comes at a cost... normally £70k upwards plus extras.
Not the answer you’re looking for I know!
6 years 1 month ago #184037 by tommylight
No spamming !
Link removed.
ASUS ROG Crosshair VIII Impact - AMD X570
4 years 1 month ago #251967 by Amerk
Hi we purchased a Nisshibo press break RT80-2550 at a supposedly working condition however as it turns out it was upgraded with LINUX CNC and the PC that was used with it is missing .
We are a little stuck as the machine cost quite a bit to transport back .
Currently we installed a different PC and bought the corresponding MESA board 5i25 .
We concluded this was the correct card because the daughter card inside the machine is a 7i77 .
i have never done anything with Linux CNC and i wanted to see if anyone here has advice for me and if there are any pres break presets we can use to avoid starting fully from scratch .
4 years 1 month ago #251973 by PCW
Its really unfortunate to lose the configuration files (hal and ini files)
as press brake setup is pretty uncommon so there's not a lot of
examples around.
Maybe someone else with a LinuxCNC press brake setup can help.
Is there no chance of getting the original PC (or just files from it ) back?
The following user(s) said Thank You: Amerk
Time to create page: 0.511 seconds
