Press Brake CNC Control & G-Code
9 years 6 months ago #90992 by andypugh
tommylight wrote: If i understood correctly, you have 2 VFD to control, no servo drives, right?
VFD need 0-10V and have their own 10V reference voltage, mesa has +-10V outputs for analog servos with its own power supply so that can be tricky.
It might even make sense to use a quantity of SPIN1X devices and a simple IO card, depending on what is needed other than the VFD control.
9 years 6 months ago #90997 by bymccoy
Two 'virtual' VFD, but it's physically one VFD and a pair of contactors that switch which motor is being controlled by the VFD. The old wiring then uses two sets of FWD/REV inputs, so that the VFD can be controlled by the NC when it switches axis (no special config with the NC required). Not sure the original reasoning (other than cost), but it's been wired so that as long as only one is being controlled at a time, the contactors and relays ensure the right NC output controls the VFD and the right motor is being fed from the VFD.
They're closed loop AC motors (both have their own encoders), but not true servos. My thought was that a servo board has a 0-10V output per motor, and has an encoder input per motor. Long term I'll be using a few servos, probably Clear Path, but even then, not sure whether to use them in stepper config (SD series) or via software (SC series). That's probably a call out question - can LinuxCNC work with the SC series ClearPath servos? Or is the stepper config better?
You're correct about the reference voltage versus the servo not having reference voltages. D'oh. Reading too many manuals and must have overlayed what I read for a different MESA board, and thought the servo outputs could take a ref voltage.
I'll be keeping the VFD for the Y axis, but the X axis I likely will swap out to direct drives (again, servo or stepper TBC). This means I could get away with using the spindle output from a 7i76 - hook the VFD to the spindle control (which also has ENABLE and DIR floating signals), and then have one encoder going through the spindle encoder... So, if I use the 7i76, I get 4x stepper axis that I can use with the ClearPath SD or any generic stepper I use. But I'm short of 2x encoder channels still.
So I need some other way of getting another 4 stepper channels and 2x encoder channels on top...
If I use steppers, I may want to fit encoders on a few axis, purely for relative homing, but the majority would just be open loop. So is there a serial daughterboard that can handle the encoders, allowing me to get another 7i76 in the future when I need those extra axis, without hogging the second interface on the 5i25 now? The 7i85 is also an option, but limits how I can drive motors in the future (unless I can get serially controlled motors).
So, revision:
- 5i25
- 7i76 (4 axis step/dir + spindle/encoder)
- 7i85 (4 channel encoder)
Any suggestions as to alternative combinations of IO card and daughtercards?
Do I maybe go for a 5i24, a 7i34 (8-channel encoder) plus 2x 7i76 (using HD-DB adapters)??
Meh... Advice please! I need to order the boards on today or Monday so I get them midweek to get the install underway...
9 years 6 months ago - 9 years 6 months ago #91002 by tommylight
You should wait for Andy or PCW to answer that. I think that you got it quite close to what you need.
Following your line of thinking, you could also go for a 7i76E and later add a 7i77, or get them both so you end up with 4 steppers and 5 servos and 2 spindles and 7 encoders and plenty of other stuff that you may or may not need. The price should be the same as for 5i25/7i76/7i77.
Also some inputs on 7i76 and 7i77 can be used for encoders, but again you should check that with PCW.
Having the 7i76E/7i77 combo has another nice feature, a single STP cable for connecting the machine, as it uses ethernet.
Last edit: 9 years 6 months ago by tommylight. Reason: added more info
The following user(s) said Thank You: bymccoy
9 years 6 months ago #91016 by rodw
The Clearpath SD is the one to use with LinuxCNC. The others are for say conveyor belt applications not for CNC motion control. If you were going to use them, I thought their claim to fame was they responded to standard step and direction signals and the encoder is wired internally eg. they only need Step and Direction from LCNC. So in that case the 7i76e might be all you need.
9 years 6 months ago #91018 by bymccoy
Thanks Tom & Rod...
Thinking that the 7i76E is the way to go. I was hung up on the PCI card approach, but I like that the 7i76E also offers two daughterboard ports, so I can get the encoders I need now with a 7i85, and then when I add other axis I can choose a 7i77 or 7i76 - but it'll probably be one of the latter as I'll use the SD clearpaths or some nice steppers I have.
I'll keep the Ethernet connectivity on separate VLANs and hardware, but is there anything to be aware of or caveats with Ethernet boards? I've not payed much attention to be docs regarding them, but gather need a realtime Ethernet driver of some kind for the host?
What is the preferred route now for new installs? I'm also needing to buy a 7i76 and 5i25 for a CNC router - should I be considering a 7i76E?? I've just upgraded a CNC mill with a 5i25/7i76 and very happy - the computer however is circa 7yrs old (an HP xw420) and seems to have some latency issues that I need to sort. Will that age of computer handle the 7i76E, or should I be looking for something newer (I've got another xw420 ear marked for the router or press brake).
Jon
9 years 6 months ago #91019 by rodw
Jon,
I found I needed 64 bit hardware for my 7i76e and it seems you have that. Other than that,
Just follow CNCnoobs Mint Installation tutorial as you have to install the PREEMPTIVE kernel so you can't use the ISO.
There is also a very good pinout of the 7i76e on the forum here.
Time to create page: 0.440 seconds
