Press Brake CNC Control & G-Code
9 years 9 months ago #86465 by bymccoy
I only thought "A" as I need three X axes... So my thought:
Press = LinuxCNC
X = X (main gantry)
Y = Y (hydraulic stroke distance)
Z1 = Z (carriage #1)
Z2 = W (carriage #2)
X1 = U (finger #1)
X2 = V (finger #2)
R = ? (gantry/finger height)
I still need R assigning, maybe an ABC? Or can I define more axes without recompiling source?
J
9 years 9 months ago #86467 by andypugh
bymccoy wrote: I still need R assigning, maybe an ABC? Or can I define more axes without recompiling source?
The limitation is with G-code. G-code only allocates the letters XYZABCUVW to axis positions.
You don't _have_ to use G-code, though. LinuxCNC allows you to choose alternative interpreters. The only example that ships with LinuxCNC is "canterp" which simply takes the internal LinuxCNC movement commands. A canterp program looks like this:
github.com/LinuxCNC/linuxcnc/blob/af15a4.../canterp_example.can
Given how little there is a press-brake code, you could make your own interpreter that (unlike G-code) considers spaces as part of the syntax, so that X1 100 would be distinguishable from X 1100. This might be more effort than you want to go to.
Do you have any examples of commercial press-brake code?
9 years 9 months ago #86481 by Todd Zuercher
Since most of these extra axis moves he needs are only positioning moves, couldn't he just use custom M-codes to command the position for undefined joints (joints that don't have an axis letter).
9 years 9 months ago #86486 by bymccoy
andypugh wrote:
bymccoy wrote: You don't _have_ to use G-code, though. LinuxCNC allows you to choose alternative interpreters. The only example that ships with LinuxCNC is "canterp" which simply takes the internal LinuxCNC movement commands. A canterp program looks like this:
I'll have a look at canterp to get a feel...
I've not got an example of press-brake code. I genuinely don't know how they store it or the standards they use - I've heard mention of G-code, but most of the software is packaged so that the user doesn't see program code, just a table of bends. I've seen some presses that even have LED strips along the front of the machine that show where a bend should be formed - this data has to be stored somewhere, so a program is more of a table/database if anything...
So, if I move away from G-code and have custom code that is basically a tabulated style code that looks like a table in raw form, I'm free then to use more axes?
Where/what is the canterp interpreter? I see a reference to a lib, but not where that lib exists in the repo?
J
9 years 9 months ago #86487 by bymccoy
Todd Zuercher wrote: Since most of these extra axis moves he needs are only positioning moves, couldn't he just use custom M-codes to command the position for undefined joints (joints that don't have an axis letter).
Hi Todd,
How would that work in implementation?
Thanks,
J
9 years 9 months ago #86505 by andypugh
bymccoy wrote: So, if I move away from G-code and have custom code that is basically a tabulated style code that looks like a table in raw form, I'm free then to use more axes?
Possibly. I think you have to actually recompile LinuxCNC to get more than 9 joints:
github.com/LinuxCNC/linuxcnc/blob/af15a4...tion/emcmotcfg.h#L23
Time to create page: 0.408 seconds
