- Thank you received: 5334
Brother TC-225 / TC-229 adventure!
9 years 2 months ago #97872
Replied by PCW on topic Brother TC-225 / TC-229 adventure!
is the per axis index_enable signal wired to the PID component?
If not this can cause a thump when index is detected
Also I've seen this when the thread order is wrong. Handling index detection is a bit tricky since the position
is zeroed when index _enable is true and the index is detected.
- ihavenofish
- Thank you received: 286
9 years 2 months ago #97876
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
all I did was check use index in pncconf wizard. ill have to check the hal/ini to see what its actually done. there definitely seems to be a thump though.
- ihavenofish
9 years 2 months ago #97900
by ihavenofish
Ok on the homing.
After setp stuff the next line is about using index.
Net x-index-enable <=> pid.x.index-enable
Should this move?
Should this move?
- ihavenofish
9 years 2 months ago #97901
by ihavenofish
Now how am I dealing with the z limit. I don't see the pins andy wrote in there already. Where would I ad it and how do I use it? Thanks.
9 years 2 months ago - 9 years 2 months ago #97910
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
The belong to "milltask" and have been there since version 2.6:
linuxcnc.org/docs/2.6/html/man/man1/milltask.1.html
Though there are more in 2.7:
linuxcnc.org/docs/2.7/html/man/man1/milltask.1.html
"milltask" is (indirectly) loaded by a reference in the INI:
[TASK]
TASK = milltask
I think that there was originally an intention to have different versions of "task" for different applications.
Note that milltask is user-space. This means that it might well not update reliably if you change values from G-code.
(And it isn't clear when the system updates its internal opinions from the values).
You might well still have to use the "W extends Z" approach.
[TASK]
TASK = milltask
Last edit: 9 years 2 months ago by andypugh.
- ihavenofish
9 years 2 months ago #97932
by ihavenofish
hmm.
Time to create page: 0.582 seconds
