Brother TC-225 / TC-229 adventure!
5 years 9 months ago #196560 by ihavenofish
you keep repeating this over and over... yet offer no actual advice on how to actually tune it better..
the general conclusion here is that with a velocity loop in the 50-100hz range, without jerk control linuxcnc cant tune out the resonance.
"tolerance" was fine. it would track better than a thou at any speed or acceleration. this was never the problem. harsh vibration was the problem on acceleration.
its a total waste of time and money to attempt to make them work, when you can sell them and buy new high end servos for a small amount of money.
5 years 9 months ago #196566 by tommylight
Sorry, lost track of it, now you mentioned it i do recall you had issues with them.
If by any chance you think i could help, feel free to use this:
www.tomberisha.com
5 years 9 months ago #196609 by timfaber
The drives where not properly tuned with the original control, Y had some weird overshoot and resonance, i will try to tune that on the drives with the original control.
The thing is with the original drives and a mesa 7i97 i have laying around i can have a go at trying to tuning them pretty inexpensive, and i can always trash that idea and buy new motors and drives. Hopefully with the help of the knowledge on this forum we can get it to perform a bit better.
5 years 9 months ago #196619 by ihavenofish
oh, you should definitely given them a try is everything is operational. just expect to have resonance issues.
5 years 8 months ago #197388 by Arkadiy
Hello. I bought a spindle servo from brother 225. I can't figure out how to connect it to 220v. Or is it necessary to connect 3 phases of 200 volts to the transformer? This is necessary for my cnc project. If I connect the servo driver to 3/380 volts or so it might break?
5 years 8 months ago #197404 by tommylight
3X380V will brake a 3X220V drive.
Most drives will work using one phase and neutral so it gets 220V, but i would not push it to hard when wired like that. Do not use 2 phases, that still makes 380V.
Time to create page: 0.111 seconds
