Brother TC-225 / TC-229 adventure!
9 years 3 months ago #96709
Not so far, though the devil is in the details
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
ihavenofish wrote: this all doesn't sound that hard no?)
- ihavenofish
- Thank you received: 286
9 years 3 months ago #96712
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
ok, computer and mesa card set up, and important brother signals for start up.
now, how do I get a start up sequence going?
basically, I need to engage the main start up relay, and then, after a second or 2, engage the Z axis brake release. where would I add this in so it happens when I "turn on" linuxcnc?
thanks.
thanks.
- ihavenofish
9 years 3 months ago #96715
by ihavenofish
hmm, I see the first half of that is easy enough, haha. (I'm at home now, so no machine in front of me, just reading the docs). just tie that button (axis.0.amp-enable-out) to an output to that relay.
so its more now attaching the brake release to that, timed a few seconds afterward.
- Thank you received: 4153
9 years 3 months ago - 9 years 3 months ago #96718
Replied by rodw on topic Brother TC-225 / TC-229 adventure!
This was discussed on another thread in the last couple of days.
forum.linuxcnc.org/39-pncconf/33069-help...i73-on-my-mill-going
Use the machine-on signal to turm on your main relay.
Then send machine-on to a timedelay component to enable your brake. Easy!
timedelay has an on delay and an off delay pin so you can decide when to trigger it when you turn it off. Probably with a time off delay of 0.
Last edit: 9 years 3 months ago by rodw.
- ihavenofish
9 years 3 months ago #96719
by ihavenofish
cool thanks!
ill read through that.
9 years 3 months ago #96733
Do you want it to be a few seconds later every time? Is there an Amp-ready signal from the Z-axis drive that could be used instead? That seems like it might be a better way.
a time-delay on a HAL signal is very easy, though.
ihavenofish wrote: so its more now attaching the brake release to that, timed a few seconds afterward.
Time to create page: 4.001 seconds
