Perfect!!
First of all I want to explain what I like to do
I was looking to build my own CNC. But building a strong CNC is not a easy task.
There's a lot involved and the cost of decent linear rails, ball screws, the frame, servo's or steppers, .. can be high.
Last week I found a Biesse Rover 18 for 1200 euro. The machine is still working fine and has been weekly used the last years. For my opinion, this is a good base to start with.
The only disadvantage is the controller. It is a NC481 and as far as I know it is only capable of running 400 lines.
This is sufficient to drill some holes, but insufficient to do more complex milling.
I was trying to find a CAD/CAM solution (Fusion 360 and and FDD replacement to USB), but even then I still have the limitations of the NC481 controller.
Therefore I started thinking about replacing the controller by a modern controller. (Mach3, LinuxCNC, .... )
With the information I got from this forum, I am sure that this is the best option.
The Rover 18 is equipped with 12 vertical boring and 4 horizontal boring spindels. There is also a 125 mm saw, and a main router.
In the first fase I would like to start with the main router only. This will give me the same possibilities as a own build router.
Later on I can try to find out how I could use the vertical and horizontal boring spindels.
So, for now I'm looking how to control the X,Y and Z-axis, the router speed, the homing sensors, the vacuum pump and the pneumatic things to position my workpiece (I don't know the name if this
I'm pretty sure that this will not be a difficult task. Especially if I can keep my servo's, encoders and drivers.
Regards
Peter
