Mitsubishi Meldas TRA 30 and TRA 60
03 Nov 2017 20:36 #101288 by andypugh
Replied by andypugh on topic Mitsubishi Meldas TRA 30 and TRA 60
A tach looks just like a little motor. Largely because it basically is. (it's a little DC generator)
03 Nov 2017 20:47 #101289 by ControlzPerson
Replied by ControlzPerson on topic Mitsubishi Meldas TRA 30 and TRA 60
Ok ya it looks like it's got one, i think at this point I should put some pics on a hosting service and then link them to this forum (pics are too large). It might make life a little easier.
07 Nov 2017 17:00 #101496 by ControlzPerson
I got around to taking a pic of the board today. I was also able to find a variable voltage on the test pin for the ER it ranged from 0 to 2 volts. My thinking is that I need to tie into this connector in the top right of the photo. postimg.org/image/27i8e2dcm3/
08 Nov 2017 16:44 #101525 by ControlzPerson
Ok so this is what I have figured out, it looks like the diagram that I found on CNC zone was fairly correct. NC ready is pin 23 it reads 24volts when the machine is on but the servo drive is off, when I hit reset and turn on the servo drive pin 23 changes to read 0.2volts so I am taking a wild guess that this is indeed NC Ready. Pin 4 changes voltage as machine speed is changed, it reads 2volts at rapid which I have tested against the test pin specified in the manual. Thanks for the help guys I'm going to start reading up on what needs to be done on the linux side of things now.
Time to create page: 1.222 seconds
