DIY CNC Camgrinder
8 years 9 months ago #104133 by schmidtmotorworks
I saw this video on youtube of a CNC cam grinder that looks like it works very well.
I have a manual cam grinder that follows a mechanical master.
It would be nice to have a CNC but I had assumed that because the very hi-end cam grinders are super expensive and still have surface finish problems that a DIY project would not be practical.
I am wondering if anyone has any ideas for what kind of hardware would be good to control the axis that moves the wheel in and out?
Would it be best to drive the rotation of the cam with a rotary table or would an encoder be good enough?
Would it make sense to re-purpose hardware off a a milling machines of are there better options for new parts?
8 years 9 months ago #104137 by johnmc1
Replied by johnmc1 on topic DIY CNC Camgrinder
Good day,
What is the problem with the cnc grinders , is it form shape or surface finish.
cheers john
8 years 9 months ago #104139 by schmidtmotorworks
I have been told that the surface looks faceted as one might expect if the motion was not smooth.
This is supposedly on machines that cost between $400K and a $million.
I suppose it could be wheel balancing or dressing but I don't know.
6 years 3 months ago #173583 by marsheng
Replied by marsheng on topic DIY CNC Camgrinder
I'm looking into this as well. Have you made any progress?
Maybe can compare notes on going ahead.
6 years 3 months ago #173585 by rodw
Replied by rodw on topic DIY CNC Camgrinder
marsheng wrote: I'm looking into this as well. Have you made any progress?
You should become familiar with external offsets. There are a number of simulators using them included with V2.8 and V2.9. Andy has done a video doing a mockup of cam grinding.
6 years 3 months ago #173594 by machinedude
Replied by machinedude on topic DIY CNC Camgrinder
i think these machine are a lot like a lathe in the respect that the work is being done between 2 centers. where things get different is how the spindle gets controlled. so rather than having a spindle that works like a lathe it would be more like a set up you would find on a milling axis of control. you need precise control over the spindle like a rotary axis in a nut shell.
things that would need to be addressed is backlash on the spindle and cross slide for the grinding wheel. if we are talking about grinding cams in motors you are getting into some close tolerance work being done so things better be spot on if you want to do this kind of work.
so as far as how to control it i don't think it would be difficult to program, i think it's more about knowing how the machine is configured and choosing the right plane to set your programs to based on how the machine is configured in respect to the axis layout of the machine.
the hard part is working all the backlash out of the mechanics of each axis and not being stingy with quality when it comes to parts.
Time to create page: 0.322 seconds
