Monarch MDT-24 Retrofit (Sharp SV-2412 w/ Fanuc 0i-MC)
8 years 8 months ago #105398 by Todd Zuercher
Have you read any of the tuning tutorials?
Are you using Halscope to look at the velocity feedback, velocity command, and following error?
What do you have the min and max following error set to? Set them to an inch or more so you can see what is happening before a following error alarm is set.
The following user(s) said Thank You: lamandesigns
8 years 8 months ago - 8 years 8 months ago #105401 by PCW
A couple of notes here:
Analog input wiring is fine (7I48 AOUT to ANALOG+ 7I48 GND to ANALOG- )
I would set FF1 to 0 to start or 1/(IPS_at_1V) if you know the axis velocity at 1V input
( 1 is likely way too high )
As Todd said, set the Ferror limits (both ferror and min-ferror) to 1 inch or so, so you can see what's happening
D is typically not required on a velocity mode servo, these are tuned chiefly with FF1 and P
Here's a link to a basic velocity mode tuning tutorial:
gnipsel.com/linuxcnc/tuning/servo.html
Last edit: 8 years 8 months ago by PCW.
8 years 8 months ago #105413 by lamandesigns
Ferror is 0.5 and 0.05. I will increase those higher and then play with FF1. Technically based on that formula FF1 should be around 0.012. I will play around the LinuxCNC tuning today to see! Thank you both!
8 years 8 months ago #105428 by lamandesigns
Well the tuning did the trick. However the numbers are much higher than I was expecting.
I have ended up with the following:
  • X: P-8000, I-2, D-25
  • Y: P-8000, I-2, D-25
  • Z: P-10000, I-2, D-30
Now this is all with FF at zero. I can't see any difference with the FF changed. What am I supposed to be monitoring?
8 years 8 months ago #105429 by lamandesigns
Teaser video with the LinuxCNC logo!
Maximum speed is currently set at 300IPM!
LinuxCNC Logo Cut
8 years 8 months ago - 8 years 8 months ago #105438 by PCW
OK, those numbers indicate that your drives are not running in velocity mode but rather torque mode...
Time to create page: 0.451 seconds
