Hi everyone,
I have done about 6 or 7 machines now with LinuxCNC and either parallel port or Mesa cards. This one however has been a big project. I purchased this machine, which is a Monarch MDT-24, a re-badged Sharp SV-2412 circa 2007. This machine was purchased originally in 2009 by the previous owner with a second machine. The second machine was just the shell and this machine was working with about 2,000 hours on it. They restored the other machine with electronics from this machine and then purchased new/used electronics for this machine over time. However they never put the machine together completely. So I purchased the machine about a year ago and started working with the Fanuc 0i-MC electronics. The more I worked on it, the less I was interested in it. I realize Fanuc is pretty darn good controls. However I was not happy with how little control I have over customizing it and the little 7" monochrome screen was just a no for me. So about November 2017, I decided to just dive in and change all the electronics and clean up all the wiring on the machine since it was a mess.
I will post more about the process so far and what I have done and how. But here is a little summary of parts used and parts that are utilized original to the machine:
- Fanuc 10HP/10,000RPM Spindle
- Fanuc alpha Servo Drives w/ alpha incremental encoders
- 16 tool ATC
- Automatic lube system
- Hitachi SJ300 VFD drive
- Elmo Cornet Servo drives - Elmo customer support has been great. Even though I bought these used, they have gone way beyond what I was expecting to help me have get it all working
- Pico Systems Fanuc Serial encoder converters - Jon has been amazing with support and the quick responses. I just don't have enough good things to say about him!
- Mesa cards: 6i24 main board, 7i48 servo interface, 7i37 front IO, 7i44 8 channel RS-422 interface, 7i73 keypad interface, 2x 7i70 remote input modules, 1x 7i71 remote output module
- AsRock Q1900 board/CPU w/8gb of memory and 64GB SSD
- 11" touchscreen 1920x1200 mounted LCD
- Original interface panel c/w pendant
- Utilizing all the original limit switches, tool changer, home switches, relays, contactors and so on.
Currently everything is operational as far as simple moves of the servos and spindle. Although control of servos through LinuxCNC is not 100% as it seems like encoder feedback to LinuxCNC sometimes doesn't read the right amount.
Below are links to some of the pictures of the process.
The day it arrived:
Before picture
Trying to clean the Fanuc stuff and mounting them:
Mount Fanuc Controls
Video showing the screen and front panel:
Front Panel
Side I/O wiring cleaned up w/ Mesa remote cards:
Side I/O
Rear drive controls w/ Pico cards:
Rear Controls
Front Main Control (need a new cleaned up photo):
Front Control
