Advice needed re; diy male/male parallel printer cable.
- muzza
- Thank you received: 6
14 Sep 2018 09:40 #117511
by muzza
Advice needed re; diy male/male parallel printer cable. was created by muzza
Hi. Not sure if this is the right place to ask or not.
I can't find a male/male printer cable anywhere here on the Sunshine Coast other than online. Trouble is, all my bits have arrived today and I want to get my Gecko 540 and servos up and running this weekend.
I was lucky enough to find an old parallel port printer cable and bought a male DB25 assembly from Jaycar electronics. I've now successfully rewired the female end and checked continuity with a DMM.
Here's my question; The Gecko manual describes pins 18-25 as "GND" but, although this printer cable has a jumper across pins 19 to 25, they're not actually 'grounded', just joined to each other. There is a conductor that connects the shell at one end to the shell at the other. Should pins 18-25 be grounded to the shell or am I right to go?
Could someone please check their cable to see if there's continuity between these pins and the shell?
Cheers in advance.
Cheers in advance.
- tecno
- Thank you received: 127
14 Sep 2018 09:59 #117512
by tecno
Replied by tecno on topic Advice needed re; diy male/male parallel printer cable.
- Clive S
- Thank you received: 486
14 Sep 2018 10:49 #117513
by Clive S
Replied by Clive S on topic Advice needed re; diy male/male parallel printer cable.
You could also get a DB25 gender changer like www.ebay.co.uk/itm/25-Way-Pin-DB25-Seria...b:g:onYAAOSwhjRaqPdc
- Thank you received: 1482
14 Sep 2018 13:46 #117530
Replied by Todd Zuercher on topic Advice needed re; diy male/male parallel printer cable.
We have lots of them around here (because we used to have several machines that used them.) Look for a parallel port extension cable.
www.cablesondemand.com/category/DB25/pro...TKiYrUxoCzigQAvD_BwE
This is the first link google popped up.
- Thank you received: 4153
16 Sep 2018 04:14 #117593
Replied by rodw on topic Advice needed re; diy male/male parallel printer cable.
Time to create page: 0.130 seconds
