VFD for a retrofitted Tree Journeyman 320 B
23 Sep 2018 19:53 #117904 by Roland2161
Hello all,
I just purchased this guy's cnc machine. www.cnczone.com/forums/vertical-mill-lat...-320-b-retrofit.html
He did a great job. Runs good etc etc. I Need to purchase a phase converter to run this at home. But I also want to buy a VFD to put on this as well. Machine has stock speed selction and motor with pulley system and H - L manual selection. I am under the impression that if I buy a VFD I can run the machine on regualar 220. Is it even possible to use a variable frequency drive with mechanical speed selection?
I am unsure of what I need to search for or where to even get started on deciding what to buy. I can just get a phase converter and run the machine, but i'd prefer to spend the money on doing the same thing, and making the machine better instead.
26 Sep 2018 12:30 #118003 by andypugh
Replied by andypugh on topic VFD for a retrofitted Tree Journeyman 320 B
With a single-phase input VFD you should be able to power the rest of the machine from single phase pretty easily.
Is the input transformer for the servo power single phase or 3 phase?
You can use variable frequency with mechanical speed selection. My milling machine has 8 gears and automatically sets the motor speed to give the correct spindle speed (if possible) in every gear. If the machine has a spindle encoder then the system can work out the selected gear by comparing VFD and spindle speed ratios.
28 Sep 2018 01:03 #118087 by Roland2161
Replied by Roland2161 on topic VFD for a retrofitted Tree Journeyman 320 B
Thank you Andy. The machine is equipped with everything needed to read rpm. It just hasn't been programmed in yet. Waiting on the wiring diagram.
I will look further into this. I will reply back with questions on the next step.
Thank you
28 Sep 2018 01:06 #118088 by Roland2161
I also believe the only thing requiring three phase is the motor. The guy I bought the machine from will forward the wiring diagram and I willwill know 100%.
28 Sep 2018 08:58 #118096 by andypugh
Time to create page: 0.224 seconds
