Fanuc retrofit retaining original AC servo motors and drives
- Thank you received: 1482
11 Apr 2019 14:11 #130661
Replied by Todd Zuercher on topic Fanuc retrofit retaining original AC servo motors and drives
What voltages are your GPIO signals? Most of the Fanuc machine I've worked with are running 24v io. A 7i50 is only 5v. I think some of Mesa's Smart Serial daughter cards may be a better option.
- Thank you received: 5335
11 Apr 2019 14:52 - 11 Apr 2019 14:53 #130667
Replied by PCW on topic Fanuc retrofit retaining original AC servo motors and drives
To interface to the the Digital Fanuc motor drives requires
1. 2 analog inputs per channel (2 phase current feedback channels)
2. 8+ TTL level or differential signals (depending on drive model)
6(TTL) or 12 (Differential) of these signals are the three phase PWM
which must reverse direction based on the driver ready signal,
as they are used for fault signaling when the drive is not ready
3. The host (linuxCNC) or a smart controller must implement commutation and FOC
This may be something better done with a STMBL drive with no power circuit
or a custom FPGA card with the correct I/O built on board
Last edit: 11 Apr 2019 14:53 by PCW.
- mclausen
11 Apr 2019 15:21 #130672
by mclausen
Replied by mclausen on topic Fanuc retrofit retaining original AC servo motors and drives
PCW:
I am switching to Fanuc A06B-6050 analog servo drives. Should I be able to drive these from a 7i48?
Todd:
Thanks, I hadn't looked at that whole section of cards. I assume I just need a 7i44 RS422 daughter card to talk to them?
Yes, the Fanuc I/O is 24 volt, but I was planning to use opto-isolators to interface to the 5 volt. The serial cards will simplify that.
Todd:
11 Apr 2019 19:44 #130691
Yes, a 7I48 will work, another option is (instead of 7I48+7I44)
7I52 for 6 encoder input and
6 Sserial channels:
--> 7I83 for analog
--> 7I84 or 7I84D for digital
This has the advantage of isolation of the analog outputs
6 Sserial channels:
--> 7I83 for analog
- mclausen
11 Apr 2019 21:00 #130694
by mclausen
Thanks. That looks like a good option. There is no speed performance problem with sending all the analog commands through serial?
11 Apr 2019 21:02 #130695
No, there are no significant delays with sserial (at least relative to 1 to 4 KHz servo thread)
Time to create page: 0.980 seconds
