andypugh wrote: photos.app.goo.gl/nwM9Ze59j3zi5TB77
Is an an album showing how I made tapered gibbs for my lathe.
The technique there doesn't need any special angle measurement, I just put the base block in the vice vaguely wonky, machined the slot, then clamped the Gib in and faced both parts off flat with the base block in the vice somewhat straighter.
Have fun with your project, you will learn a lot. Main that lathes make poor millsA lesson i learned myself doing that project.
AnnoyingMutt wrote: Don't ask me how I found out how much those beds flex.
Tho to be honest I was able to machine all the bits and bobs to do a a wheel swap on my Monster. 1040 pushed the limits (I was give a 50mm bar at the local metal supplier so that was the suff used for top hat spacers)...... The sprocket carrier just fit..just
