Stepper motor - loss of steps
7 years 4 months ago #138120 by persei8
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 44000
setp stepgen.0.dirsetup 44000
Your DIR setup and hold times of 44000 are probably OK but steplen and stepspace should be set to something like 10000 or even 20000. These numbers are nanoseconds so 10000 would give a value of 10 uSec.
7 years 4 months ago #138121 by PCW
Replied by PCW on topic Stepper motor - loss of steps
The OP is using the "reset" mode so step time is set by the reset time here:
setp parport.0.reset-time 5000
7 years 4 months ago #138122 by persei8
(U32) parport.<portnum>.reset-time -- The time (in nanoseconds) between a pin is set by write and reset by the reset function if it is enabled.
Interesting. I did not realize it worked like that.
7 years 4 months ago #138125 by pl7i92
5microstepping is also a steplos killer
better to use externel timingbelts for balscrew it is 20/25 teeth so 1,25 gear
that brings in 0,01mm per step at halfstepping
and gets a full speed full torque running mashine
the
color code is most
A+ RED
A- Blue
B+ Green
B- Black
if you change like most Black /green it will likly loos at higher speed at around 100RPM of the stepper
7 years 4 months ago #138167 by Jocman
persei8 wrote: setp stepgen.0.steplen 1
Uhmmmm.....I'm getting a little bit lost
Ok, I understand the change of values for stepspace and steplen (I'll change to 15000, in the middle, according to your suggestion)
pl7i92 wrote: 5microstepping is also a steplos killer
the
color code is most
A+ RED
A- Blue
B+ Green
B- Black
But I'm a little bit confused about this, if you can kindly explain me the thing....
BTW, as suggested by persei8, I'm planning (wife and job allowing - and weather too, my garage is hot like an oven) to overhaul the mechanics and the wiring too, hopefully in the next days
7 years 3 months ago #138850 by Jocman
Past week I checked the structure, then this weekend I checked the electronics and stepper.
When disassembled the steppers, I found the X coupler broken.....
Maybe an invisible crack (factory?) wich eventually gave up.
Well, I'll go on with the review of all (mechanics and electronics) and see what will go on.
Time to create page: 0.233 seconds
