Is the Ecoca EL4610e a good candidate for a retrofit?
5 years 8 months ago #199535 by andypugh
the_crack_fox wrote: I Bought this machine and put an Adtech 4620 controller on it.
Well, I hope that works out well for you, but means that this forum is not likely to be any help.
4 years 8 months ago #236102 by Hytek
I have just purchased one of these lathes and I'm looking to retrofit/upgrade the control system. And I found myself here. I was wondering how did this conversion work out? Did you manage to retain the apron handwheel operation?
4 years 8 months ago #236105 by andypugh
You can certainly retain handwheel operation with LinuxCNC. My own lathe has jogwheels in the conventional locations for just this reason.
4 years 8 months ago #236106 by Hytek
Thanks for the speedy reply. I will have the lathe home by the end of this week, then I can have a better look at what I am dealing with. At the moment it has a communication to NC unit issue. Trying to decide if I look into that first so I can assess the rest of the machine or just jump straight into the retrofit. Don't want to waste too much time/money fixing a problem that may well be redundant.
Time to create page: 0.225 seconds
