- Thank you received: 91
MulBe039 wrote: Very interesting,
Out of curiosity: did you end up buying and/or converting that lathe? /quote]
Sorry no. It was too far away..
dm17ry wrote: the machine seems to have a gearbox spindle and though the spindle drive mostly handles it transparently for the controller, i will probably need to add a few HAL pins to the driver for gear selection
dm17ry wrote: and porting/re-implementing the ladder will require some effort... but all should be doable
dm17ry wrote:
i'm far from being a big fan of that ladder logic notation. it's far easier for me to rewrite everything in c or python. so i myself would definitely would start from scratch and won't try to port anything from the meldasmagic64 to the linuxcnc. but being able to look at what they have there would be useful.
MulBe039 wrote: The servodrives and the encoders will be handled by your board&.software. These receive instructions from linuxCNC based on the entered gcode.
This includes selected gear detection, absolute position of the machine and the spindle index pulse as well as the pulse generation.
there're number of points where the e-stop can be wired... yeah, have a look first at the machine schematics and ladder how they do it.I'd like to handle the E-stops outside of software, so that they work reliably even when the computer has problems. For this I will take a closer look at the relay board that they are currently wired into and see if I can't reuse anything around there.
Or is there a sort of 'standard procedure' here that is used with linuxcnc?
i doubt there's any analog sensors - pretty sure they all end up with a discrete 24VDC outputsI will need to identify how these pressure- temperature- and oil-level sensors operate and figure out how to easily inteface these with the new controller. I'm assuming they're probably analog. Do yo perhaps recognize in the parameter list (attached below) what the treshold values for these sensors are for which they trigger?
i would definitely keep 24VDC circuits as they are and use compatible I/O cards. mesa or my YIO.The way I currently see it, I think the most sensible way to go about this would be to take out the BASE I/O unit & the REMOTE I/O UNIT, hook up a step down converter to the 24VDC that energize all these circuits to prevent it from frying the control electronics and hook up all the buttons from the console directly to an I/O card or a parallel port.
