Pressure-ok sensor?
  • JetForMe
  • JetForMe's Avatar Topic Author
  • Elite Member
  • Elite Member
28 Jul 2019 04:31 #140786 by JetForMe
Pressure-ok sensor? was created by JetForMe
In my CNC router table build, I'd like to include a pressure-ok sensor, so it doesn't try to operate the ATC unless there's good air pressure. I'm looking for a 24-V sensor that has a 24 V output, and something like a 1/4" NPT female port, available in different threshold pressures, like 120 psi. I've done some googling but haven't had much success finding anything.
Anyone have any recommendations?
Thanks.
28 Jul 2019 05:03 #140787 by PCW
Replied by PCW on topic Pressure-ok sensor?
Something like this should work:
www.ebay.com/itm/1-4-Adjustable-Diaphrag...0:g:H28AAOSw03lY70Rc
Beware compressor control switches as they will have very high hysteresis
28 Jul 2019 06:12 #140788 by rodw
Replied by rodw on topic Pressure-ok sensor?
Correct. I think the 12 volt one in my 4WD is like 100 psi on and 150 psi off which is ideal when you want an air tank with > 90 psi in it and enough air to reseat a tubeless tire on a rim.
  • JetForMe
  • Elite Member
  • Elite Member
28 Jul 2019 06:39 - 28 Jul 2019 06:39 #140789 by JetForMe
Replied by JetForMe on topic Pressure-ok sensor?
Hmm. Anything from a reputable vendor? I'm willing to pay for quality. What I wanted to avoid was building an interface circuit for it to my 24 V Mesa digital I/O.
Last edit: 28 Jul 2019 06:39 by JetForMe.
28 Jul 2019 06:53 #140790 by rodw
Maybe something from SMC?
www.smcworld.com/products/en/s.do?ca_id=518#rp
28 Jul 2019 13:38 - 28 Jul 2019 13:46 #140802 by PCW
A pressure switch doesn't need any interface
I would chose a NO switch
Here is a switch from a more reputable supplier:
sensing.honeywell.com/switches/standard-...e-switches/mh-series
Last edit: 28 Jul 2019 13:46 by PCW. Reason: MH series seems better
  • Moderator
  • Moderator
28 Jul 2019 14:06 #140804 by tommylight
Replied by tommylight on topic Pressure-ok sensor?
What pressure ?
For 2.5 to 3 bar, use car manifold pressure sensor at 10 to 20 euro new, very reliable and measure from -3 to 3 bar, depending on the model. Analogue output from 0.2 to 4.8V.
For 5 to 5.5 bar, use a plasma air pressure sensor, no price info, they are used in all smallish plasma cutters, 7 bar on big ones. Digital output, NO or NC pins.
If space is no issue, use a compressor pressure switch used on all compressors to turn the motor on or off, they are all adjustable for low and high limit usually up to 11 bar. Here 17 euro a piece.
28 Jul 2019 15:49 - 28 Jul 2019 15:51 #140806 by pl7i92
Replied by pl7i92 on topic Pressure-ok sensor?
the Festo ones work like a Induktiv limit switch
Festo 527467 Drucksensor SDE5-D10-O-Q6E-P-M8
25Euros
its 0-30V
and 0-10bar
you can edit the point of trigger
www.ebay.de/itm/Festo-527467-Drucksensor...6E-P-M8/173396834484
Last edit: 28 Jul 2019 15:51 by pl7i92.
28 Jul 2019 17:11 #140814 by tecno
Replied by tecno on topic Pressure-ok sensor?
25Euros
its 0-30V
and 0-10bar
No it is 15 to 30V
Time to create page: 0.540 seconds
