Retrofit BP VMC DX32 with siemens drives
01 Aug 2019 19:48 #141137 by btvpimill
Retrofit BP VMC DX32 with siemens drives was created by btvpimill
Has anyone done a retrofit on old Bridgeport DX32 VMC with Siemens drives? My machine is fine but losing the BMDC card. It seems like the drives are just looking for an analog voltage to move (maybe +_5VDc?)
Encoders are in use of course.
22 tool tool changer
Would like to keep rigid taping
01 Aug 2019 20:18 #141139 by btvpimill
Replied by btvpimill on topic Retrofit BP VMC DX32 with siemens drives
Oralternatly I also have a discovery 308 that I could steal the BMDC from it to fix my VMC. Then I would need to retro the 308. Big John did you ever do that to yours?
12 Aug 2019 19:14 #141985 by andypugh
Replied by andypugh on topic Retrofit BP VMC DX32 with siemens drives
Sorry for the late reply. If the servos are +/- 10V (or 5V) and the encoders are standard quadrature then LinuxCNC should be a fairly easy retrofit.
Rigid tapping is built in to LinuxCNC. All you need is a spindle encoder.
Time to create page: 0.771 seconds
