Retrofit Leadwell MCV 600XL
7 years 1 month ago #146116 by tommylight
danilom wrote: I ordered them from one company in Bulgaria this is link to their shop Vallder
Do you have to pay taxes for stuff from Bulgaria ? How much is the delivery and how long does it take ?
Serbian:
Da li moras da placas porez za stvari iz Bugarske ? Koliko kosta postarina i koliko traje prevoz ?
Regards,
Tom.
7 years 1 month ago - 7 years 1 month ago #146277 by danilom
Replied by danilom on topic Retrofit Leadwell MCV 600XL
They have a local distributor in Serbia, because owner is from here so items get delivered directly, Prices are without VAT.
After careful measuring it seems that Y drive has short cables, also originally cables have been inside protective hose and because of connectors on encoder cable it will be impossible to pull them trough. So I will reuse the original cables , lots of soldering but less complicated than to pull trough all new cables.
image missing http://cnc.rs/wp-content/uploads/2019/09/0-02-0a-882c6259918af3cf10294792e4e56e63e891760f3bfe583744cd7433e052e15e_6bf8b131_1569511295.jpg
image missing http://cnc.rs/wp-content/uploads/2019/09/0-02-0a-d5eab0545aaa2f1d420913efe131a8bb681b75bd1c2cd90515ffa2853c53f401_4d0905d4_1569511295.jpg
Last edit: 7 years 1 month ago by danilom.
7 years 1 month ago #146307 by tommylight
danilom wrote: They have a local distributor in Serbia, because owner is from here so items get delivered directly, Prices are without VAT.
Web? Address? Phone no?
Thank you.
Hvala.
7 years 1 month ago #146329 by danilom
Its on their contact page I already sent you
vallder.com/sr/kontakt
The following user(s) said Thank You: tommylight, Clive S
6 years 8 months ago - 6 years 8 months ago #156653 by danilom
At last got some time to connect everything
image missing http://cnc.rs/wp-content/uploads/2020/02/IMG_20200204_165733-Medium.jpg
Ofcourse there is a problem , It seems it has something with the drives, because I can not eliminate the effect with Linuxcnc tuning.
first drive on X tunes fairly well (about 0.015mm ferrror on start and stop and 0.002 while moving), but has some oscillation while moving. Second drive on Y needs 0.1 I so the ferror centers on line and can not be tuned as good as X. Third drive on Z (counterbalanced) has constant oscillation and needs I = 3 to lower the static ferror down to centerline. It wont tune right , moving up is smooth but down is bumpy and in halscope it is seen as oscillation.
image missing http://cnc.rs/wp-content/uploads/2020/02/IMG_20200206_152248-Medium.jpg
image missing http://cnc.rs/wp-content/uploads/2020/02/IMG_20200206_175816-Medium.jpg
I have the manual for the drives , they are set for velocity mode P0-1 = 4 . There are two AGND pins 35 and 36, if analog gnd is connected on pin 35 it wont work, so I tried on 36 also and connecting both together.
Servo drive manual
Tried P and I parameters in drives Cotrol parameter section P1-0 and P1-1 , cant seem to help , lowering P1-0 leads to poor responce, Tried P1-1 up to 3000 it just slows down the response.
Also tried P3-08 Speed feedback filter time parameter ... from default to 0 ... no help its always the same.
Anyone has any suggestions ?
None of the motors seems sto stand still and hunting .
Last edit: 6 years 8 months ago by danilom.
6 years 8 months ago #156659 by tommylight
Search for
tuning granite devices argon drive
There are a lot of info so might find something useful there.
Tuning the drives itself is paramount to having a working system, and any tuning of Linuxcnc with improperly tuned drives will only cause headaches and lots of lost time.
Time to create page: 5.606 seconds
