replacing original Zaxis glass scale with a import
- jamby
- Thank you received: 6
24 Sep 2019 15:56 #146085
by jamby
replacing original Zaxis glass scale with a import was created by jamby
HI
Looks like i maybe replacing my original Zaxis glass scale with a import from china. The current unit is a acu-rite 10um unit for the 4.5 inch travel of the spindle. The replacement I am looking at is a 150 mm 5um unit.
Big question is can Linuxcnc handle the change in accuracy and will my bridgeport clone become more accurate at the same time??
Jim
Jim
- Thank you received: 7496
24 Sep 2019 16:09 #146092
Replied by tommylight on topic replacing original Zaxis glass scale with a import
Yes it can and it should.Big question is can Linuxcnc handle the change in accuracy and will my bridgeport clone become more accurate at the same time??
The following user(s) said Thank You: jamby
- pl7i92
- Thank you received: 358
25 Sep 2019 06:52 #146135
by pl7i92
Replied by pl7i92 on topic replacing original Zaxis glass scale with a import
Hi
what Interface are you using
as the Incoming pulses will double at the time
What is the encoder conected to
the brigeport usaly use Standard stepper so no use of encoders
so if real servos are on YES you will see a better performence on a Encoder scale increese
Time to create page: 0.073 seconds
