G203v use of the enable feature for something???
12 Jan 2020 01:08 #154656 by mooser
Getting ready to install the new control box I've been building for my lathe and I just looking at the gecko g203v drives and started wondering about the enabled pin
On the last controller I had a switch wired to them so I could disable an axis if I wanted to, now as it turned out I don't think I ever used that feature even once so I didn't include it this time.
While the control board is out on the bench I'm wondering if there is any reason I might want to wire it into the 7i76 somewhere for some reason that just escapes me at this time?
Safety?
Machine has no hand-knobs left so pretty hard to move manually
Anyway, appreciate any input or suggestions
M
12 Jan 2020 03:03 #154660 by Leon82
I thought about sending the disable thru the other half of the estop switch back to terminal 12 but ended up just using an output for a relay for the driver power supply.
12 Jan 2020 03:58 #154662 by rodw
I think the only use for the disable pin is to disable the drive when hitting estop. But apparently, using a relay on an estop (to switch 5 volt to the disable pin from field power) is not compliant. Its better to drop the mains power to the stepper power supply which can usually be done mechanically on the estop switch itself. Even Gecko show no connection to that pin.
12 Jan 2020 14:48 #154674 by mooser
That's more or less what I've got now. The e-stop disables the 7i76, which in turn breaks the coils for the spindle and drive board contactors
If I had manual handles I'd wire something into the disabled inputs but I just can't think of any reason to have them otherwise
M
Time to create page: 0.972 seconds
