Engraver Spindle Collet and/or replacement
- Mike_Eitel
- Thank you received: 183
04 Feb 2020 16:58 #156520
by Mike_Eitel
Replied by Mike_Eitel on topic Engraver Spindle Collet and/or replacement
May this could be a solution if you find a way to fix.
vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?...V4&item=264330647182
No glue if it is worth the money..
- dzawacki
- Thank you received: 6
04 Feb 2020 17:04 #156521
by dzawacki
Replied by dzawacki on topic Engraver Spindle Collet and/or replacement
Yeah...that has absolutely nothing to do with the topic.
Also, not going to give my banking details to a site that cannot even get a security certificate.
04 Feb 2020 17:04 #156522
I haven't found one, in literally minutes of searching.
Do you have a lathe? I seem to recall that there is a thread in the end, you could screw in a 50mm extension.
(Or machine down a C8, though there might not be enough wall thickness.)
Which brings us back to making a spindle from scratch. Which looks pretty easy given that it is held in by a clamp.
Replied by andypugh on topic Engraver Spindle Collet and/or replacement
If anyone knows of a supplier that has a 150mm C6, I'd love to hear about it!
- dzawacki
04 Feb 2020 17:12 #156523
by dzawacki
If it can't be found in minutes of searching then it isn't worth my time
I don't have a metal lathe, but that would be a fun project if I did.
I think, creating one from scratch with a 6mm OD steel rod and a collet clamped to the end would be easy enough for me to do. I'll investigate that option.
04 Feb 2020 17:24 #156524
I think it's a link from eBay, ie this item:
www.ebay.com/itm/264330647182
- dzawacki
04 Feb 2020 17:44 #156525
by dzawacki
I guess, and it does have a 6mm shank on it. But there's no way that will fit in my machine. :/
- Thank you received: 1482
04 Feb 2020 17:53 #156528
Replied by Todd Zuercher on topic Engraver Spindle Collet and/or replacement
Maybe an electric die grinder.
www.ebay.com/itm/HEAVY-DUTY-LONG-SHAFT-E...5738.m4383.l4275.c10
- AltPartsInc
- Visitor
10 Feb 2020 13:52 #156950
by AltPartsInc
Replied by AltPartsInc on topic Engraver Spindle Collet and/or replacement
Second, only to the
engraving
table, the spindle is an extremely important part of the engraving system. This is true for manual as well as computerized engravers. Spindles are precision manufactured mechanical components that operate at variable speeds during rotary engraving.
- bbsr_5a
- Thank you received: 106
10 Feb 2020 13:55 #156952
by bbsr_5a
Replied by bbsr_5a on topic Engraver Spindle Collet and/or replacement
for a engraver a cheep china DC spindle ER11 woudt be good at 400W and 24k RPM
10 Feb 2020 14:03 #156955
You are sounding a bit like a spammer.
Second, only to the www.altparts.com/trumpf] engraving table, the spindle is an extremely important part of the engraving system. This is true for manual as well as computerized engravers. Spindles are precision manufactured mechanical components that operate at variable speeds during rotary engraving.
Time to create page: 1.479 seconds
