Default CNC equipment recommendation ??
07 Mar 2020 08:35 - 07 Mar 2020 10:03 #159383 by WillieOsgood
Default CNC equipment recommendation ?? was created by WillieOsgood
I'm a Facilities Superintendent at a state part with previous CNC experience with
Link Removed
I've been task with purchasing a CNC Router for our Carpenter Shop to primarily make signage - but hopefully many other things as well.
I've only been budgeted with $12,000 to purchase a complete work center and I need recommendations because that looks like only half the budget I actually need.
Are there any good, complete, router packages available in the 10k range allowing the other 2k for tooling?
Last edit: 07 Mar 2020 10:03 by tommylight. Reason: removed link
  • Moderator
  • Moderator
07 Mar 2020 10:01 - 07 Mar 2020 10:02 #159395 by tommylight
Replied by tommylight on topic Default CNC equipment recommendation ??
Link removed.
Last edit: 07 Mar 2020 10:02 by tommylight. Reason: removed link
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
07 Mar 2020 10:17 #159396 by BeagleBrainz
Replied by BeagleBrainz on topic Default CNC equipment recommendation ??
Link Removed
  • Moderator
  • Moderator
07 Mar 2020 13:30 #159414 by tommylight
He has put some effort in it, so i let it slide......after removing the link.
Do not know about this link as i am on the phone so i can not check, but some of those links can make a mess out of a windows computer when clicked, less of a mess on Linux systems. On windows it can attack and acces everything, on Linux only the browser.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
07 Mar 2020 18:53 #159431 by Todd Zuercher
Replied by Todd Zuercher on topic Default CNC equipment recommendation ??
For only $10k you will get the most for your money with a used machine.
  • BeagleBrainz
  • Visitor
  • Visitor
07 Mar 2020 19:48 #159432 by BeagleBrainz
My paranoia is telling me the OP may originate from the same place as the 5 tips for CNC engraving. Just advertising.
  • Moderator
  • Moderator
07 Mar 2020 22:11 #159440 by tommylight
We are still waiting on those 5 tips !
The following user(s) said Thank You: BeagleBrainz
08 Mar 2020 16:12 #159478 by bbsr_5a
Replied by bbsr_5a on topic Default CNC equipment recommendation ??
on that budget is woudt be best to get a Retrofited full Garantied from a reseller as there are all over the world
building is FUN but takes Time and lots of NERVES
  • Moderator
  • Moderator
08 Mar 2020 16:49 #159484 by tommylight
Where ?
For that price you get an old used and battered ( but massive ) machine or a chinese crappy one that will have the table sagged in about a week of use, already dealt with several of them.
The "Maho retrofit kit" on ebay is more than that, alone, and the quality is ...... i do not know, never found anyone actually used them.
Time to create page: 0.197 seconds
