E-Stop Wiring
  • dzawacki
  • dzawacki's Avatar Topic Author
  • Senior Member
  • Senior Member
29 Mar 2020 12:56 #161965 by dzawacki
E-Stop Wiring was created by dzawacki
The last piece of hardware I need to wire up is my emergency stop button and I want to make sure that I'm doing this correctly.
I have a Mesa 7i96 and my spindle is not controlled by the board. Ideally, if I push the e-stop both the machine stops moving and the spindle stops spinning. That being said, my plan is:
Wire the switch inline between the power and the spindle driver.
Wire the switch as an input for the 7i96.
Does that sound correct?
29 Mar 2020 13:00 #161966 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic E-Stop Wiring
Sounds promising.
What is your spindle motor.
Can you show your e stop wiring diagram
29 Mar 2020 16:19 #161989 by andypugh
Replied by andypugh on topic E-Stop Wiring
One way to do this is with a two-switch e-stop button.
On one of my machines I have the e-stop interrupt the 24V feed to the main contactor, and LinuxCNC gets the 24V coil feed as an input. But if you do that I think the input ought to have a protection diode.
Time to create page: 0.116 seconds
